Given the following circuit,
Re Model of CE Configuration - Emitter Biased
When Ro is not infinite, from the book, ZB is given as,
Input impedance
However, when it's infinite, the input impedance is easily obtained as the parallel combination of RB and β(re+RE). Given that it's not infinite and I need to derive the input circuit to find the input impedance as well as ZB, how would I draw it and derive the formula to gain intuition? Similarly, the output impedance how would the circuit look?
Arcadius
  • 75
  • See the example of finding Zout = Vx/Ix using "test voltage techniques" https://electronics.stackexchange.com/questions/265046/calculation-of-output-impedance-of-ce-emitter-bias-configuration-unbypassed-wi/276764#276764 – G36 Apr 09 '23 at 18:54
  • [Closely related question asked by the OP](https://electronics.stackexchange.com/questions/662049/transistor-re-model-input-output-analysis) yesterday. – Andy aka Apr 09 '23 at 19:24
    May I ask you a question? What do you want to achieve? What is the point of finding **Zb** that includes the **ro** in the first place (and doing all this math)? When we never use this equation in the real world when we design the amplifier circuit. – G36 Apr 09 '23 at 19:34
  • @G36 I want to learn to derive the formula to gain intuition because the book has exercises with ro being not infinite. When ro is infinite Zb is β(re+RE), making the Zi = Rb || Zb or Rb || β(re+RE). I'm trying to find Zb when ro is not infinite and how that would change the circuit's Zi. With that how the input circuit would look like and gain another perspective. – Arcadius Apr 09 '23 at 22:07
To be able to find \$Z_b\$ that includes the translator output resistance \$r_o\$. We need to find the voltage at the \$V_e\$ node in the first place. Because I'm going to use the test voltage method to find \$Z_b\$
$$ Z_b = \frac{V_{test}}{I_{test}} = \frac{V_{test}}{\frac{V_{test} - V_e}{r_{\pi}}}$$
The circuit looks like this:
I will use brutal force -> nodal analysis. And the math software will do the math part for me.
We have two nodes. Thus, the first equation:
$$\frac{V_e}{R_E} +\frac{V_e + V_{test}}{r_{\pi}} +\frac{V_e - V_o}{r_o} - \beta \times\frac{V_{test} - V_e}{r_{\pi}} = 0 $$
And the second node equation:
$$\frac{V_o}{R_C} + \frac{V_o - V_e}{r_o} + \beta \times\frac{V_{test} - V_e}{r_{\pi}} = 0 $$
And after we solve this
$$V_e = V_{test} *\frac{R_E (R_C +\left(\beta +1) r_o \right)}{r_o r_{\pi} + R_C (R_E + r_{\pi}) + R_E ( r_{\pi} +(\beta +1) r_o)}$$
$$V_o = V_{test} \times\frac{R_C\: R_E - R_C\: r_o \beta}{r_o\: r_{\pi} + R_C(R_E + r_{\pi}) + R_E ((\beta +1)r_o + r_{\pi})} $$
We plug the \$V_e\$ into \$Z_b\$ and solve it.
$$Z_b = \frac{(R_C + R_E + r_o)r_{\pi} + R_C R_E + R_E \:r_o + R_E\: r_o \:\beta}{R_C + R_E + r_o}\tag{Equation 1}$$
And now we can simplify it further but we have to do it manually because the software cannot give as a answer in a "human wanted form".
$$ = \frac{(R_C + R_E + r_o)r_{\pi} + R_C R_E + R_E \:r_o + R_E\: r_o \:\beta}{R_C + R_E + r_o} = r_{\pi} + \frac{R_C R_E + R_E \:r_o + R_E\: r_o \:\beta}{R_C + R_E + r_o} $$
$$= r_{\pi} + \frac{\frac{R_C R_E}{r_o} + R_E + R_E\:\beta}{\frac{R_C + R_E}{r_o} + 1}$$ $$= r_{\pi} + \frac{\frac{R_C R_E}{r_o} + R_E\:(\beta + 1)}{\frac{R_C + R_E}{r_o} + 1}$$ $$= r_{\pi} + \frac{R_E \left(\frac{R_C}{r_o}+(\beta + 1)\right)}{\frac{R_C + R_E}{r_o} + 1}$$
And this is the end. Also, notice that this method does not give us any circuit intuition.
To gain some intuition we could try to apply the Miller theorem (a very strong simplification).
And view the \$r_ o\$ as a resistor with the smaller resistance \$\frac{r_ o}{A_V}\$ connect in parallel with the \$R_E\$ resistor.
simulate this circuit
And now we can clearly see why \$Z_b\$ decreases in value when we include \$r_o\$.
Equation 1 can be formed into: $$Z_{b}=r_{\pi}+\frac{R_{E}\left(R_{C}+r_{o}\right)}{\left(R_{C}+R_{E}+r_{o}\right)}+\frac{R_{E}r_{o}\beta}{\left(R_{C}+R_{E}+r_{o}\right)}$$ which reveals a circuit intuition of three resistances in series: $$Z_{b}=r_\pi+R_E//(r_o+R_C)+R_\beta$$ where $$R_\beta=\frac{R_{E}r_{o}\beta}{\left(R_{C}+R_{E}+r_{o}\right)}=R_\beta'\beta$$
The first two terms are easily found by removing the dependent current source (\$\beta = 0\$) in the OP's original diagram.
The resistance modulated by \$\beta\$ is almost \$R_E//r_o\$ but with the denominator increased by \$R_C\$, Not quite so intuitive but acceptable.
\$R_\beta'\$ can be further analyzed but may not add to intuition but is interesting none the less: $$R_{\beta}^{'}=\frac{R_{E}r_{o}}{R_{C}}//R_{E}//r_{o}$$
RussellH
  • 12,496
G36
  • 13,642
  • G36, Do you mind if I add a circuit intuition to your answer? You have done the work that I would have done in my own answer. If you don't agree with the intuition you can roll back my edits – RussellH Apr 10 '23 at 00:08
  • @RussellH I see no problem with that. You can add it. – G36 Apr 10 '23 at 07:26
