I have been trying to derive Av , Ai , Zi , Zo from a two port system model of a transistor. I know that the input voltage must be the voltage at the base to ground, and the output is from collector to ground. It seems that I have a confusion about which current I should consider the input and which current is the output.
In the following diagram the input current shows it is coming from an AC source. However, in the book it states that it is Ib. The output current is clearly shown that it's derived from Rc. Would it be safe to say that Ii comes from RB?
When the transistor has a voltage divider network at the base would it change the input current? If so, to which component?
