I've got a HAT board with five status LEDs I'd like to get somehow extended to the front panel of my system, so that I can read its status without opening the enclosure. the five white rectangles you can see on the picture near the bottom edge of the board are the LEDs:
The almost obvious solution is fiber optic cable: I've got some 20 cm long PVC-coated 2 mm diameter glass fiber. The retailer suggested me to use Loctite to glue the end of the fiber to the transparent LED casing. NO USE: Everything (fiber, coating, and even my fingers, ouch!) got glued, but not the casing of the LED. Unfortunately, there are no holes or other parts I could attach the cable to, so what shall I do?
