The figure of merit is not number of bits, but effective number of bits times bandwidth.
20ish bits is about as good as it gets in a 20Khz bandwidth (there are no real 24 bit converters in that bandwidth), and by the time you are looking at a 60MHz bandwidth you might on a good day manage 13 bits or so.
But there is a trick to all this, iff the ADC is correctly dithered (And the RF ones usually have more then sufficient uncorrelated noise at the input to do this), then every time you halve the bandwidth in your digital filters and decimators you lower the total noise power in your remaining bandwidth by 3dB, so dropping the bandwidth by a factor of four gets you an extra bit....
Consider a 14 ENOB bit ADC @ 125Ms/s, by the time you have decimated down to ~8KHz you have gained 7 bits, giving you 21 bits effective into your post processing in a reasonable SSB bandwidth, or nearly 20 bits in a 16khz bandwidth.
FM does of course suffer from rather large channel bandwidths, nature of the beast.
