I am learning about control strategies for DC-DC converters.
While I find voltage mode control easy to understand, I struggle to understand current mode control.
Is the idea here to control the output voltage by controlling the inductor current?
If so, what is the relation between them?
JRE
  • 67,678
  • 179
  • Your diagram is missing a few steps in relation to your text. Perhaps you should expand it to include inputs and outputs? – Tim Williams Mar 28 '23 at 19:43
It is a vast subject to discuss but, basically, with voltage-mode control, the error voltage delivered by the compensator directly sets the duty ratio \$D\$. By doing so, you adjust the output power delivered by your converter, according to its dc transfer characteristic like \$V_{out}=DV_{in}\$ for a buck converter:
The duty ratio is elaborated via a pulse-width modulator (PWM) block made of a comparator and an artificial ramp pulsing from 0 to a peak value \$V_p\$. When the ramp intersects with the error voltage (a flat dc level in theory), then toggling occurs, turning the main transistor off. By changing the dc error voltage - the loop does that by monitoring the deviation of \$V_{out}\$ from its target - you directly adjust the duty ratio and ensures regulation. In this mode, you don't need to consider the inductive current \$i_L(t)\$ to operate the converter. You actually implement a current limit but for safety reasons and not for regulation purposes.
In current-mode control, it is different. The sawtooth is replaced by the inductor current which is also a ramp. This current can be directly observed by a current transformer or via a resistive shunt which delivers a voltage image. The error voltage will now set the inductor peak current cycle-by-cycle and will adjust the value based on the operating point: a high peak for a large output power, a low value in light-load conditions:
In this mode, you control the inductor peak current and indirectly the duty ratio \$D\$. If you operate the buck converter in voltage- or current-mode control, \$D\$ will be identical between the two converters for a similar operating point. It is only the way this duty ratio is elaborated that changes between the two. This time, you must monitor the inductor current cycle-by-cyle and it provides inherent protection to the converter.
Below is a quick summary between the two techniques and each bullet is a subject to expand in itself : ) You can have a look at my last small seminar on the subject:
Verbal Kint
  • 20,420
  • 50
As a simple qualitative explanation, if you put an inner control loop on the inductor current, you turn the inductor into a current source (within the BW of the loop, etc.). The voltage loop "programs" more current in the inductor as the load increases to keep the output voltage constant.
At a high simplistic level, this has the effect of removing the inductor from the LC filter, and making the control-output transfer function a single-pole system, the current source feeding the output capacitor (and load).
On a less simplistic level, you have to add slope compensation to deal with potential subharmonic oscillations, and you wind up with a pair of complex poles at half the switching frequency. The pole due to the inductor actually just moves out to a higher frequency.
But current mode is easier to compensate than voltage mode and has better line regulation and disturbance rejection, among other advantages.
John D
  • 22,677
  • 39
  • 56
