I am trying to build a test application circuit for an AFBR-5813TQZ IR (1300 nm) optical transceiver. For now, I am only trying to verify that the transmitter works, so I have breadboarded the recommended application circuit from the datasheet, fed 3.3V into Vcc from one power supply, and fed 1V across TD+ and TD- from another power supply with separate grounding via a twisted cable (LVDS). The voltage values were obtained from the recommended operating conditions section of the datasheet.
I am detecting light power output with a lab bench power meter and a short plastic optical fiber cable. However, I do not detect anything when the circuit is powered. I am reasonably sure that the detector and connecting fiber is not at fault because I successfully detect the output of a similar setup with a AFBR-5972EZ (650 nm) optical transceiver and the appropriate settings.
I have verified and remade my breadboard circuit connections multiple times now, so I am reasonably sure I have built the recommended application circuit as specified. Probing the pins of the transceiver also yields voltages I would expect, about 3.3V on Vcc, +0.5V on TD+, and -0.5V on TD-, with respect to the ground of the Vcc power supply. I have multiple copies of the transceiver component as well, so I do not think it is a faulty component causing the issue.
I have frankly never used optical transceivers before, so I am not sure how to proceed. Unfortunately, I do not have another IR source at my disposal to test the detector. I would appreciate any suggestions or advice and can provide more information on my setup if requested. Thanks!
EDIT: I am editing my post to provide more information on my light detection. I am using a 1936-R Newport Optical Power Meter. I used a 400-1100 nm detector to detect the 650 nm light and a 780-1800 nm detector to detect the IR light. For both optical connections, I use the same 1m optical patch cable from Fibertronics. From the datasheet, it uses Corning SMF28 fiber, which seems to be rated for IR wavelengths.
