Please help me understand the calculation in this table. The writer has a 12V batery connected to a 12V/110V inverter connected to standard house-hold AC appliances.
The calculation for the 1000W induction stovetop is:
1000W/12/0.85=98. 98*0.75h=73.5Ah (where 0.85 is 15% power conversion loss.)
Shouldn't it be 1000W/110V/0.85=10.7. 10.7*0.75h=8Ah?
JRE
  • 67,678
  • 179
grunt
  • 113
  • Your question alone shows your misunderstanding, it should be "Watts of an AC device to amp-hours of a battery", and there you would have an answer to your confusion. – Edin Fifić Mar 27 '23 at 15:21
  • Note that AC power in North America is 120V not 110V. It hasn't been 110V since Vietnam. It matters on this kind of calc, since it's 9%! – Harper - Reinstate Monica Mar 28 '23 at 04:19
If you were running the stove-top from AC you would use 120 V to figure the current, but they are calculating the Ah drawn from the battery so they use 12 V.
If you drew 8 A from a 12 V battery for an hour that would only be 96 Watt-hours, hardly what you'd expect for a stove.
So, you need 1000 W for the stove, to get 1000 W at 12 V the current would be $$ \frac{1000W}{12V} = 83.333A$$ Running the stove for 45 minutes it would use $$83.333A\times0.75h=62.5Ah$$ Accounting for 85% efficiency $$\frac{62.5Ah}{0.85}=75.53Ah$$ Which agrees with their calculation.
GodJihyo
  • 17,628
  • 45
