I am specifically looking to replace a 12V 3A power supply that seems to have disappeared from a backup HDD. I found a 12V 5A power supply with the right connector on Amazon, and ordered it without hesitation as I've always "understood" that as long as the power supply was rated for at least the peak current the device might draw, it was fine.
But now that I've had time to consider it a bit, I'm less sure… Having tinkered a bit with TI's designer tool it seems there is considerable room for optimizing the supply circuitry with the expectation of a particular range of loads. Will a "typical" off-the-shelf, switching power supply brick rated for 5A deal gracefully with all loads from 0-5A?
A little knowledge is a dangerous thing, as they say… Is my "understanding" that the higher-rated supply is safe / reasonable actually correct?
