I am studying the Cockcroft–Walton generator and one question comes to mind.
Let's say we have a load consuming every watts the generator can provide.
Would it be wrong to state that the generator would need to disconnect it's output from the load and wait n AC cycles to be able to generate the same voltage again , where n is the number of stage(s) in the generator ?
Ex:
Voltage source AC : [-3V, +3V]
CW Module 1 Output : [6V]
CW Module 2 Output : [12V]
CW Module 3 Output : [24V]
We see here that it takes 3 AC cycles to go from [3V] to [24] volts.
If a load then consume all this power stored in the CWMs capacitors in an instant, for the generator to be able to "charge" up to 24 volts again, it would need to wait for 3 more AC cycles, correct ?
