Why is air gap important in flyback transformer?
$$\color{darkblue}{\text{Short story}}$$
A gapped core has a lower peak flux density for the same inductance carrying the same current. This means it is less likely to suffer from core saturation problems. Put another way, it can tolerate a higher energy transfer to the secondary winding if primary current is increased.
$$\color{purple}{\text{Longer story}}$$
For a flyback transformer, the most fundamental thing to get right is the primary inductance. So, with an ungapped core, you might use 10 turns to get a required inductance of 100 μH.
$$\color{orange}{\text{I'm using convenient numbers to illustrate the point}}$$
When you introduce an air-gap, the core permeability drops and, to counter this, you need more turns to get the original inductance value. So, if the permeability reduces by a factor of four (due to the air-gap), 10 turns only gets you 25 μH.
To restore the inductance from 25 μH to 100 μH, you need to double the turns to 20.
$$\color{red}{\text{This is because inductance is proportional to turns squared}}$$
So, your gapped transformer has 20 primary turns and the ungapped transformer has 10.
"So what" you might say?
$$\color{blue}{\text{Here's where the benefit is seen (reduction of magnetic saturation)}}$$
The "things" that cause the magnetic core to saturate are current, turns and permeability. But, of course, the current in the ungapped core still has to match the current in the gapped core to ensure the correct level of energy is transferred each switching cycle.
We can't do anything about that; current and inductance make the energy to be transferred.
So, the gapped transformer (compared to the ungapped transformer) has: -
- Twice the number of turns (bad for avoiding saturation)
- One-quarter of the magnetic permeability (good for avoiding saturation)
Hence, the peak flux density in the gapped core is half the peak flux density of the ungapped core. That is why we gap many, many magnetic components.
If we are going to wrap all the windings of transformer to the airgap
what happens?
Because of fringing fluxes around the air-gaps, we tend to be careful about applying windings in those areas because the copper wire local to those spots can heat up excessively. So, just be careful about this.
It's better to apply several smaller gaps than one big gap because fringing is less with a smaller gap. And, of course, we can find ferrite materials that have low permeability (in effect, the gap is homogeneously distributed around the core).
How should we consider the equivalent circuit of a standard flyback
transformer?
I treat a flyback transformer no differently to any other transformer; two (or more) highly coupled coils. How we think of the flyback transformer in a circuit is a little different because we need to recognize that a flyback design doesn't push significant energy through the secondary circuit when the primary inductance is being charged hence, we use dot notation on circuit diagrams and ensure we are diligent when we wind the transformer.
