In this App note, page 7, example 3, can someone tell me from where the values for IBN and IBI are coming from? I.e.
\$I_{BN}\$ = -(5 nA + 0.5 nA)
\$I_{BI}\$ = (5 nA - 0.5 nA)
I'm using this MCP601 Op-amp
Ibn and Ibi are input bias current currents. They result in the small current that leaks into the high impedance terminals of the opamp (have to have some resistance for the amplifiers of the opamp to measure the signal, they designers try to make the resistance as high as possible for the application).
For the MCP601 they are found here, and vary with temperature.
IBN = -(5 nA + 0.5 nA)
IBI = (5 nA - 0.5 nA)
They are inherent to the operation of the input stage of the opamp. Some small current has to move into or out of the input pins or the transistors will not function. For the part number you mention, the values are on the datasheet as shown in another answer. The values in the app note are typical, not related to any specific part number.
