A curiosity, but why do the mounting holes on PCBs have those small holes on the outer chainring?
Asked
Active
Viewed 58 times
Those are vias to connect the outer layer seen in the image to other layers. – winny Mar 14 '23 at 09:00
They are for electrical conductivity.
They allow to connect the copper area of the mounting hole electrically between different copper layers, to have a good connection from the metallic screw on top and metallic chassis mounting stand to ground plane.
Justme
- 127,425
- 3
- 97
- 261
1If good connection from the metallic screw on top and metallic chassis is required then why isn't the fastener hole plated thru ? – D Duck Mar 14 '23 at 09:19
@DDuck maybe because that could eventually wear off. Which is an extremely unlikely scenario... – tobalt Mar 14 '23 at 09:22
1The question https://electronics.stackexchange.com/questions/137394/mounting-hole-on-a-pcb shows a photo of a variety of mounting holes, one with a ring of vias surrounding a plated thru hole and one without. And pretty well explains that the main hole isn't plated thru to avoid small metal particles being generated -- and that the vias are for electrical conductivity and mechanical stiffness to avoid the bearing pad from lifting off. – D Duck Mar 14 '23 at 09:27
@DDuck Impossible to know why. There might be a good reason but we don't know why that board does not have a large plated through mounting hole. The nearest PCB that I am looking at does have a large plated through mounting hole. – Justme Mar 14 '23 at 09:29
