Could you help me identify this transistor?
I have searched every SMD code decoder and can't find the exact type of this transistor:
It apparently has CCE1X written on it, and has a SOT-23-6 package if I’m not mistaken.
It’s part of a router main board, blown because of using a wrong power adapter (the polarity was reversed).
ocrdu
  • 8,705
  • 30
  • 42
Nandosuke
    It is probably not a transistor. It is more likely a switch mode power supply integrated circuit. The large black things marked "4R7" are inductors (coils.) – JRE Mar 13 '23 at 09:30
  • Is there any chance I could replace that? – Nandosuke Mar 13 '23 at 09:54
  • The hint that it is a SMPS IC may not be enough to help you find a replacement - I took a quick look and couldn't find anything that matches. It might be easier to find out what voltage those two regulators were supposed to produce and replace them with separate modules. You'd remve the IC and probably other parts of the circuit, then wire in voltage regulator modules to the power input and output. – JRE Mar 13 '23 at 09:57
  • I haven’t checked what voltage that runs in the circuitry, since it just happened, but the external wall adapter output is 12 volts – Nandosuke Mar 13 '23 at 10:08
  • Can’t find it but it’s probably a synchronous buck IC, considering the surrounding components. – winny Mar 13 '23 at 10:11
  • Perhaps 5V and 3.3V, or 3.3V and 2.5V (or 2.0V, 1.8V, 1.5V...) – rdtsc Mar 13 '23 at 12:44
0 Answers0
