15
What battery chemistry would be most suitable for an application where the cells are expected to sit a very long time, say 100 years, disconnected, with minimal self discharge?
Assume the storage temperature would be something on the order of outdoor extremes experienced in inhabited places on Earth, say -50°C to 50°C or so.
Assume the operating temperature range would be narrower, say 0°C to 30°C or so.
It need not be a chemistry currently available in any commercial products. Assume environmental concerns can be overcome.
Assume the current demands are relatively low, for a small electronic data processing load and that physical space can be found to make a battery of sufficient capacity.
Assume that a hard switch (not a semiconductor) will disconnect the battery from the load.
It doesn't have to be a voltaic cell necessarily, just a self-contained means to store or generate electric energy. It must not rely on external sources of energy like sun, wind, water, or physical effort (like cranking a dynamo) which might not be available when the system is finally turned on.
To clarify the intent, this would be for a "time capsule" type use where it's expected to be sealed into construction, but must be able to power up in the future with no expectation of available external power.
Theodore
  • 2,061
    Wet cell chemistries stored without water and well-sealed can last a long time; the battery doesn't really start being a battery until you add water to it. I don't know about 100 years, though. – Hearth Mar 08 '23 at 16:33
    Does it have to be a battery in traditional sense? How about solar cells, RTG/nuclear, thermal generator, hydrogen cell, watermill, or wind generator? – Justme Mar 08 '23 at 17:34
  • @Justme Question edited to clarify. – Theodore Mar 08 '23 at 17:55
    Does it need to be a chemical battery? Can you pack a hand or foot-powered generator with assembly instructions? Coils, magnets, and mechanical parts, stored properly, are likely to last as long as anything else you can store in there. – Matt S Mar 08 '23 at 18:08
    Are there constraints on size? – Nat Mar 09 '23 at 01:54
    Please don't dig down batteries or other forms of electronic waste in the wilderness. 100 years from now on we'll likely be regarded as a bunch of clueless idealists who aimlessly damage the environment. Around 100 years back, this guy https://en.wikipedia.org/wiki/Thomas_Midgley_Jr was regarded as a genius. Among his inventions were leaded gasoline and freon for refrigerators. Today we can conclude that he didn't have a clue of the consequences of his inventions. We can only guess what people 100 years from now on will think of that guy who was digging down batteries left and right. – Lundin Mar 09 '23 at 15:55
    As commented below, be careful in choosing **all** the components, esp. capacitors. No electrolyte-based ones, possibly no ceramic ones (moisture sensitive). Provide a thick conformal coating to everything. Maybe you can be luckier with temperature: if the device is *buried* somewhere it will reasonably stay far from the outside high and low – LuC Mar 09 '23 at 16:44
    The battery may be the least of your problems in a 100 year time capsule. [This one was only fifty years.](https://en.wikipedia.org/wiki/Miss_Belvedere) Water seeped in and ruined the 1957 Plymouth Belvedere that was enclosed in it. – JRE Mar 09 '23 at 17:01
  • @Lundin I said nothing about burying anything at all. I never indicated a quantity greater than one, much less about "digging down batteries left and right." I had something [like this](https://mattfife.com/wp-content/themes/mattTheme/headerimgs/2022/01/froggycornerb-1.png) in mind. – Theodore Mar 09 '23 at 19:20
  • "electronic data processing load" you're going to need a non-volatile memory technology that's good for 100 years... is that a different question? – Jasen Слава Україні Mar 11 '23 at 09:25
  • @JasenСлаваУкраїні I figured mask ROM would do it. Am I mistaken? – Theodore Mar 11 '23 at 16:42
9 Answers9
16
A gravity-battery might be designed to drop a weight, generating energy, when the time-capsule's opened.
A gravity battery is a type of electricity storage device that stores gravitational energy, the energy stored in an object resulting from a change in height due to gravity, also called potential energy. A gravity battery works by using excess energy from the grid to raise a mass to generate gravitational potential energy, which is then dropped to convert potential energy into electricity through an electric generator. Energy generated from a gravity battery is a form of sustainable energy. One form of a gravity battery is one that lowers a mass, such as a block of concrete, to generate electricity. The most common gravity battery is used in pumped-storage hydroelectricity, where water is pumped to higher elevations to store energy and released through water turbines to generate electricity.
"Gravity battery", Wikipedia [links and references omitted]
Nat
  • 397
    This was my second thought. First thought was springs. A compressed metal spring should be able to store energy for a long time and could be smaller/lighter than a gravity battery. – Michael Mar 09 '23 at 08:47
    Over the space of 100 years, a metal spring would certainly lose _some_ of its energy - would need a decent metallurgist to quantify how much. – MikeB Mar 09 '23 at 17:44
    I fail to see how a battery is needed in the first place - an electric motor can be stored in a dry place or even in vacuum for 100years and a spring + crank is enough to make it run for the duration of the product's use in the future. It all depends on how much power is needed, but again no long-shelf-life battery should be expected to have a lot of power capability. – Mister Mystère Mar 09 '23 at 23:57
    All the answers are good, but I've decided to accept this one because I like the "frame challenge" and potential energy seems like a better bet as long as we can seal up the mechanical bearings well enough to make sure they'll still spin. – Theodore Mar 21 '23 at 21:06
14
The longest operating battery: https://en.wikipedia.org/wiki/Oxford_Electric_Bell
No exotic chemistry required, but it's very effectively insulated so as to prevent self-discharge.
pjc50
  • 46,540
  • 64
  • 126
A nuclear-diamond battery is probably the best choice, they could last for 100's of years.
In 2018, researchers from the Moscow Institute of Physics and Technology (MIPT), the Technological Institute for Superhard and Novel Carbon Materials (TISNCM), and the National University of Science and Technology (MISIS) announced a prototype using 2-micron thick layers of 63Ni foil sandwiched between 200 10-micron diamond converters. It produced a power output of about 1 μW at for power density of 10 μW/cm3. At those values, its energy density would be approximately 3.3 Wh/g over its 100 year half-life, about 10 times that of conventional electrochemical batteries.[6] This research was published in April of 2018 in the Diamond and Related Materials journal.[7]
Source: https://en.wikipedia.org/wiki/Diamond_battery
Voltage Spike
  • 75,799
  • 80
  • 208
Industrial Zinc-air batteries have a very long shelf life. They need to be activated (pull-tab) and require an oxygen environment which may invalidate this battery for your needs.
qrk
  • 7,474
    You have to hermetically seal them against oxygen. I came across a box of zinc-air hearing aid batteries ~15 years old and they were all dead. – user71659 Mar 09 '23 at 05:52
  • @user71659 Zinc-air coin cell batteries have a shelf life of approximately 3 years. It's the reason I stated "Industrial" as those batteries supposedly have much better sealing. – qrk Mar 09 '23 at 16:54
    Issues aside, stating something has a "very long shelf life" without addressing whether than covers the OP's stated 100-year requirement doesn't mean anything. – chepner Mar 09 '23 at 17:24
Thermal batteries (an unfortunate name because they are not hot until activated) are used in military applications such as missiles. They are activated by a built-in pyrotechnic charge and have an advertised shelf life of 50 years. It's not hard to imagine a greatly extended shelf life through improved sealing.
They typically produce a great deal of electric power for a relatively short amount of time, such as the amount needed to steer a missile using strong servo motors. Since you need lower currents, you could combine a thermal battery that runs for a few minutes together with a supercapacitor for long duration, low power use.
To activate, you could pull a pin that allows a spring-loaded hammer to strike an internal primer. Within milliseconds, great gobs of power would be flowing to charge your supercapacitor.
MTA
  • 481
  • I wouldn't advise any electrolyte-based capacitor: within a few years of shelf life, they become unusable. Even a humble MLCC can pose a risk, soaking too much water from the ambient. – LuC Mar 09 '23 at 16:34
    +1 This is the answer for current-day demands that look like this. Molten-salt batteries can have runtimes of hours (limited by the pyrotechnic charges keeping the salt liquid, you could chain them to get even longer runtimes), provide many amps of peak current, and have a certified shelf life of 20 or 50 years for weapons. You could design them for 100-year storage. – Mark Omo Mar 10 '23 at 04:33
Let's assume we're talking an Earth-bound solution. If the location has a consistent ambient thermal gradient available, and your power needs are low, perhaps a thermopile combined with some energy-harvesting + storage setup could work. This is kind of like using a radioisotope thermal generator (RTG) as used in spacecraft, but without the hazardous material risk (not to mention the government red tape in obtaining such a device.)
An idea that could provide round-the-clock power:
  • Day harvesting - lensed solar to heat the thermopile hot side, cool side in the ground
  • Night harvesting - ground-source heat to the hot side, cool side in air
Challenge: thermopiles are very inefficient (about 7.5%.) But with a large enough pile and big enough gradient you can get useable power. Piles sold for use with woodstoves generate hundreds of W. More about those here: https://www.tegmart.com/
Now, if the requirement is that the device have a means to power itself when opened, but otherwise isn't powered on, then why not solar? With the cells protected from the elements until the capsule is opened, the cells will not age like they do when exposed to light and heat.
Likewise, a wind or water turbine, hand crank, or some other electromechanical generator could generate power. There's kind of a neat wind approach that uses a single, flexible blade: https://www.bridgestone.com/bwsc/stories/article/2019/11/13-2.html
Finally, I think power supplies that use a triggered chemical reaction are problematic for long term, because of shelf life. That said, an 'idiot-simple' solution could be a lead-acid battery that has its electrolyte separate. Open the capsule, pour in the electrolyte and you have a pretty big battery at about 50% state-of-charge.
hacktastical
  • 49,832
  • 47
  • 138
I would try going back to basics and supply the separate parts to make a Voltaic pile: copper and zinc plates, cardboard separators and salty brine along with instructions. You could scale the electrode area and stack height to get the required current and voltage for your load.
Richard
  • 399
  • Anything with electrolyte stored separately will do. Dry substances are extremely inactive. – fraxinus Mar 10 '23 at 07:18
  • yes, lead-acid for instance can be stored dry. and easily rehydrated. could be an easy win if the electronics can run off a single 2V cell. but only slightly more complex more voltage is needed. – Jasen Слава Україні Mar 11 '23 at 23:56
  • +1 for volta pile if power demands are low. There are examples of Zamboni plies that are still working centuries after they were sealed.... https://en.wikipedia.org/wiki/Oxford_Electric_Bell – bigjosh Mar 15 '23 at 01:25
Thinking out of the box here: does the energy really have to be inside of the "battery"?
Maybe include a solar panel hooked up to the device, along with instructions for the future users that they need to place it in sunlight?
Or... if you expect there not to be any sun anymore by the time they discover the time capsule: a dynamo with hand crank, along with instructions that they should spin the crank?
Opifex
  • 505
  • Ah, but what if they can't read? – Theodore Mar 09 '23 at 19:44
    @Theodore you can always use pictograms, symbols or drawings. I mean... we can understand what 10.000 year old cavedrawings depict, right? – Opifex Mar 09 '23 at 22:07
  • We can recognize an ice-age painting of a buffalo as being a buffalo, but if the paintings at Lascaux were directing us to *do something specific*, I think we missed out. – Theodore Mar 21 '23 at 21:03
  • @Theodore The cave paintings hold a message. They tell us a story. Not instructions. We can clearly see the story they are telling: it's them hunting animals. Now, if you add pictures of a human (can be a drawing or even a photograph) doing whatever is necessary top use the device, then any futuristic civilization will be able to figure it out. – Opifex Mar 21 '23 at 21:27
Not exactly a "battery" but for the application, a fuel cell might work well. Use spring energy to puncture sealed tanks of hydrogen and oxygen, and a moment later a second mechanical device creates a spark, and your fuel cell roars to life. Once it's operating & producing power, an electronic controller could throttle the feeds to regulate the output.
Ralph J
  • 119
