I want to design a gate driver board to drive 6 SiC MOSFETs/PWR IGBT where the VBus can go up to 1200V. I need to use an isolated DC-DC power supply that can make dual bipolar rails (+15V/-8V) from a 15V input, something like the below image.
My first question: Is it necessary to use this approach, meaning all gate drivers are powered with individual isolated power supplies?
I used the formula below found in this document to calculate IGBT drive power and it came out to be 1.5W.
My second question: Is this method of calculating drive power for IGBTs right?
Then I looked into some reference designs for bipolar DC-DC power supplies for gate drivers but I didn't find any that matched my needs because most of them either have a custom-made transformer or a chunky and expensive one.
Here are some reference designs I found:
Isolated Push-Pull Power Supply Circuit
Isolated Bias power and Gate Driver daughter board
This one below actually looks like a good choice but the design is a four layer board with a high component count:
Isolated IGBT Gate-Drive Push-Pull Power Supply with 4 Outputs
If I have to go with this approach (all gate drivers are powered with individual isolated power supplies) I need to have a low cost, small-footprint power supply to go with the small form factor gate driver board I am designing.
