I'm using the onboard software watchdog facility of an Atmega328 like documented here.
My purpose is to limit to 2 seconds the execution of a portion of code that could lead to endless computation.
This is the pseudo-code scheme:
enable watchdog (2 seconds)
run may-be-endless code
clear watchdog
run the rest
The rest of the code should be run if the may-be-endless code manage to run in the given amount of time, otherwise the whole program must be restarted.
This is the Arduino code I loaded into the board:
#include <avr/wdt.h>
void setup() {
  Serial.begin(9600);
  Serial.println("Started");
  wdt_enable(WDTO_2S);
  Serial.println("watchdog ON");
  wdt_reset();
  Serial.println("watchdog OFF");
void loop(){
  Serial.println("loop...");
  delay(1000);
At this point, the expected output should be an endless printing of loop... messages, after the ones in the setup (Started, watchdog ON/OFF).
Surprisingly, what I get instead is this:
Started
watchdog ON
watchdog OFF
loop...
loop...
loop...
Started
watchdog ON
watchdog OFF
loop...
loop...
loop...
Started
watchdog ON
watchdog OFF
loop...
loop...
Appartently the watchdog is being set but can't be cleared. How come?
etuardu
  • 397
wdt_reset()
does not disable the watchdog, it merely resets its timer, delaying the expiration.
You probably want
wdt_disable()
However, your overall approach may not be the most sound - letting the watchdog expire can be clever, but it is also fairly heavy-handed compared to approaches such as using a normal timer interrupt or having your code limit itself. Normally the watchdog is for unanticipated errors.
Chris Stratton
  • 33,282
  • 43
  • 89
  • Thank you... I feel ashamed that I didn't check `wdt_disable` before, it was that easy. I was distracted by several how-tos that I read which stated that `wdt_reset` was the way, and also the documentation was a little bit ambiguos to me. – etuardu Apr 15 '13 at 15:44
To disable the watchdog timer call wdt_disable(). All wdt_reset() does is reset the watchdog timeout, which in your case is redundant: you just turn it on two lines above. wdt_reset() does not turn the watchdog timer off (contrary your serial output).
angelatlarge
  • 3,611
