Unless you know exactly what you're doing, and for some insane reason you need very exotic behavior (which you don't), you should never return the main function on an embedded controller.
In other words: don't ever return the main function in embedded C.
Add a while (1) {}
on the line before return;
. That's usually the place where your application runs from the main context (as opposed to the interrupt context).
void main(void)
// low level / peripheral inits
// application inits
beginTransmission(ADDR);
sendControlByte(0x40);
for (unsigned char i = 0; i < 8; i++)
sendCommand(0x01);
endTransmission();
// !!! add missing while-forever loop !!!
while (1)
// application code
return;
Your code executes and then returns from main, which can cause behavior you don't expect.
Relevant question: Who receives the value returned by main()?
I'm adding the relevant part of the original code for reference, since the external source can change or be removed at any time:
#include "CONFIG.h"
// I have to mention that I run MCU from 5V pins from Arduino Uno. Pins SDA and SCL of display are pulled-up.
void main(void)
// I have two LEDs on pins RC3 and RC4 to check if MCU works.
TRISC = 0b000000;
PORTC = 0b011000;
__delay_ms(1000);
PORTC = 0b000000;
// Searching through Internet I found some causes to resets - PO and TO bits.
// Here I am checking them. Also they are negated, so LEDs must light up.
if (__timeout && __powerdown) PORTC = 0b011000;
else if (__timeout && !__powerdown) PORTC = 0b010000;
else if (!__timeout && __powerdown) PORTC = 0b001000;
__delay_ms(2000);
// I suppose PIC resets here 'cause LEDs blink with those periods.
PORTC = 0b000000;
i2cBegin();
setupI2C();
sendControlByte(0x00);
sendCommand(0x26);
sendCommand(0x00);
sendCommand(0x05);
sendCommand(0x00);
sendCommand(0x07);
sendCommand(0x2F);
endTransmission();
sendCommand(0x01);
endTransmission();
// Test: blinking LEDs program
TRISCbits.TRISC0 = 0;
TRISCbits.TRISC1 = 0;
while (1)
PORTC = 0b000001;
__delay_ms(2000);
PORTC = 0b000010;
__delay_ms(2000);
return;
