I am driving an inductive load and have a situation where an SCR will be forward biased but conduct in reverse. Can it do that if I strobe the gate the entire time I want it to conduct in reverse?
Update: I edited the question to stipulate significant conduction, as opposed to leakage. I assume the device will leak a small amount when reverse biased.
James Strieter
  • 373
    Provide more details. you question need clarification. terms bias and strobe should be explained. – user263983 Feb 23 '23 at 09:41
  • Bias refers to anode-cathode junction. So forward biased means there is positive potential from anode to cathode. Strobe means provide a current pulse through the gate. – James Strieter Feb 23 '23 at 10:58
  • You can use the SCR to short a bridge or use two SCRs back to back. – Gil Feb 23 '23 at 21:39
The simple answer to your question is that an SCR will not conduct in reverse, ever.
As user263983 says, you need a triac if you want to conduct both ways.
Also remember that once its triggered, it will continue conducting until the current flow drops to zero.
Useful description here:
https://eepower.com/technical-articles/an-introduction-to-triac-basics/#
OXO
  • 60
  • There is always current in reverse, even if just leakage. – Tim Williams Feb 23 '23 at 13:09
    @TimWilliams I think what OXO's saying is that an SCR cannot conduct far more than leakage current in reverse. For example, if the device has a leakage current of 1 uA, it cannot conduct 1000 A backwards. If you agree, can you kindly remove the down vote? – James Strieter Feb 23 '23 at 13:24
Yes. Leakage current will flow, and some of the free charges created by the G-K bias, bleed through the anode layers, increasing leakage.
See: Should I gate SCRs on when reverse-biased?
Tim Williams
  • 22,874
  • 71
