I have often see ball grid array (BGA) chips, mostly those from CPUs or GPUs, being glued around in the corners with some red glue or to the perimeter with a translucent one.
Having to manually solder BGA chips using hot air, should I glue the chips to the board before heating?
In their answers to a quite similar question about soldering small electronic parts (but not specifically BGA chips), some users mention that glue can cause additional problems when it is not applied properly: adhesive glue before soldering
Not having an assistant, such soldering process remains currently challenging for me, as I hold the hot air gun (from a rework station) in one hand and the tweezers in the other one.
Without using glue, I see at least three difficulties:
  • positioning and aligning the chips precisely
  • maintaining the surface of the chips parallel to thus of the PCB when bringing them to it
  • remaining stable during the soldering, without false move nor trembling
So, my questions are:
  1. Is the use of glue recommended, given the context?
  2. Are there possibly alternative compounds to help keeping the chips into place during the soldering, like a kind of "butter" that would progressively melt when reaching high temperatures?
  3. Are there other improvements that I can make to facilitate the soldering of the BGA chips?
JRE
  • 67,678
  • 179
OuzoPower
  • 181
    BGAs should autoalign by capillary forces during soldering. If you glue it, that force is defeated. How will you align it? – winny Feb 21 '23 at 14:53
  • Thank you winny! Good to know. I assume that curved tweezers with flat tips (e.g. Hakko CHP 105-SA) will be my best friend to maintain the chips until the surface tension forces auto-align the chips. – OuzoPower Feb 21 '23 at 15:58
  • You can buy BGA components for tens of cents. If you're worried, pick up something cheap, order a practice board and solder a few until you get the hang of it. – user1850479 Feb 21 '23 at 18:38
7 Answers7
12
To add on to the other excellent answers, and to answer your third question: the red glue you see is likely to be some kind of corner staking or underfilling. After soldering, an adhesive compound is added to mitigate in-the-field failure, particularly when packages are subjected to thermal or physical stresses. It's not intended to improve solderability.
See the ANSYS website for more info.
Matt S
  • 3,234
  • 32
What you see around the corners is most probably not glue, and certainly not put there to hold the chip in place during automated assembly.
Some SMD components need to be glued down after the soldering, as in case of a PCB with components on both sides, when you flip it upside down to assemble the other side some components might fall when the solder is liquid. This happen in case the surface tension of the molten solder is not enough to hold them in place.
That said, it is possible that it is just a sealing compound that is put there to avoid moisture penetrating below the chip, especially for chips that might get hot, such as a CPU or GPU. Moisture can penetrate below the part, and diffuse inside the chip itself, depending on the package technology, and when the chip heats up the water can become steam, and crack certain parts of the chip. To avoid this, you bake the parts before soldering, you solder, and then shut the sides to avoid any moisture ingress.
How can you solder your BGAs is not a single-answer question. This entirely depends on what pitch we are dealing with, PCB thickness, PCB status (new/used) and equipment you have.
A good recipe is to use a very (very very very) thin amount of really thin (as in runny) flux on the PCB, place the part, hot air & pray. You might need a hot plate if the PCB is particularly thick/big, and if it is small enough you can get away with the hot plate only.
And absolutely, categorically, no glue.
TonyM
  • 21,742
  • 39
  • 62
Vladimir Cravero
  • 16,007
  • 38
  • 71
  • Thank you Vladimir! I encounter the specific case of an SSD with chips on both sides. So, I will have to glue some chips before flipping it upside down. The PCB is thus of a Kingston SSD, and identical to the one visible on this page: https://www.digit.in/reviews/pc-components/kingston-a400-ssd-240-gb-review-125099.html . Thickness : 0.85mm. Status: used (for 1st attempt) and new (if donor PCB needed). The NAND chips have BGA132 layout, 1mm pitch and balls seem being 0.2mm diameter. Interesting chip positioning technique using polyimid film (Kapton): https://www.youtube.com/watch?v=T75VzHjnExc – OuzoPower Feb 21 '23 at 15:43
  • 1 mm pitch should not be impossible. Solder one side, glue them, flip, solder, enjoy. And good luck! – Vladimir Cravero Feb 21 '23 at 16:04
  • Thank you. Any recommendation for the glue type? Red expoxy one? UV hardening one? Other? – OuzoPower Feb 21 '23 at 16:13
  • I am sorry I cannot help you on this topic - I have never used such a product, I just know they exist. I would guess that even CA glue might be acceptable, or any epoxy... It needs to hold the parts only through one reflow cycle. – Vladimir Cravero Feb 21 '23 at 16:21
Personally, I'm intimidated by the whole idea of BGA rework with hobby grade equipment, and really wouldn't do it.
But, no, if I were doing it, I would be very hesitant to glue the chip in place. Surface mount soldering relies on letting the surface tension of melted solder being able to pull the chip into alignment. Gluing would prevent that from happening.
The issue is that with hot air, you may have problems getting all the balls molten at the same time. I really wouldn't even consider personally trying it without using a board heater to bring the temp just below the eutectic point, and then using hot air to nudge the region of the board over melting.
Note that facilities that do BGA rework often have xray devices to check the results. Certainly, you would need to be able to tolerate errors, and be able to run a functionality test to verify correct placement.
Scott Seidman
  • 29,274
  • 44
  • 109
  • @Thank you Scott. I am planning preheating the board with a small convection owen to around 50°C below the solder melting point, and to blow air around 30°C to 50°C above the solder melting point, protecting other components from desoldering with 250°C/300°C polyimid film (Kapton) and where possible additional thermal shield (aluminium foil). I plan soldering with leaded balls, in order to reduce thermal stress and make the solder process easier. I could possibly apply the hot air nozzle on a drill stand and ask some external help. – OuzoPower Feb 21 '23 at 16:09
    My colleague soldered BGA eMMC using just a preheater and hot air, and it did work. Granted, eMMC is much easier, as only about twenty of the 150 balls are actually connected at all. – jaskij Feb 22 '23 at 21:27
    1. No, absolutely no glue should be used on BGAs prior to reflow. BGA solder balls collapse slightly during reflow, increasing contact with the pad, and any adhesive would interfere with that.
    1. The solder paste holds the chip in place prior to the melt, then surface tension during. No need for anything else.
    1. For backside components, limit the BGA size / weight depending on the solder paste contact area. If you can’t avoid this, you may need to do a 2-pass reflow with higher melt solder on back for pass 1, then lower-melt solder on top for pad 2. This adds cost of course.
You can consider using NSMD pads to increase solder-to-pad contact area (and thus, surface tension) during reflow. NSMD pads have proven more mechanically robust than SMD pads for very fine-pitch BGAs.
Finally, make sure your board planarity is well controlled. Also your package planarity needs to be specified and assured by the vendor.
The glue you're seeing isn't for soldering. It's 'corner staking' applied after the reflow process for improved shock-and-vibe mechanical robustness. It's a reduced type of underfill where adhesive is injected between the corners of the soldered BGA and the board, as opposed to complete underfill which is injected underneath the entire IC.
More here: https://www.ansys.com/blog/bga-and-qfn-failure-mitigation-underfilling-edge-bonds-and-corner-staking-physics-of-failure
hacktastical
  • 49,832
  • 47
  • 138
  • 1. Thank you. 2. I plan using leaded solder balls and not solder paste, although I'm aware solder paste being a viable alternative. 3. I have no choice on the size of components, as I'm not myself creating circuit boards. I had in mide repairs through reballing. PCB planarity: thank you for mentioning it, although it is not relevant in the context of my repair jobs. However, I will pay attention to having solder balls of equal heights, and equalize with "sandpaper over stencil" if necessary. – OuzoPower Feb 21 '23 at 16:32
  • For (2), you still need solder paste to achieve the proper wetting, whether you’re doing assembly or rework. – hacktastical Feb 21 '23 at 17:32
  • Thank you very much for the tip. Can you please tell more about applying solder paste to achieve the proper wetting for rework (with reballing). Do I have to apply a thin layer of solder paste to the PCB, additionally to the new solder balls that are on the chip, to facilitate the thermal conduction / wetting? How thin should it be? Should it be applied through the stencil, or can it be applied to the whole surface where the chips will be put into place? For BGA with leaded 0.2mm solder balls with 1mm pitch, for wetting should I use leaded T4 paste or one with even thiner balls? Thanks. – OuzoPower Feb 23 '23 at 12:21
  • Generally, you will need to apply the paste using a stencil. The thickness of the paste will be similar to that used when the board was manufactured. The finer details of this are specialist knowledge that you could find out from the rework station vendor. I don’t happen to know the exact solder, tape, stencil, thickness, temperature, nozzle time, etc. off the top of my head. – hacktastical Feb 23 '23 at 17:28
The "red" glue you are seeing is an SMT red glue and it's a certain type of temperature-set adhesive. Normally most assembly houses will not be using these adhesives, as surface tension will position the components correctly. However that is the "theory" ... In practice and depending on the circumstance, it may be required or used sometimes. I know for sure that hand soldering small BGAs based on the common idea of "surface tension will center it naturally - don't worry" is pie in the sky ! If the hot-air gun blows too strongly, as they often do, even on minimum setting, you will quickly blow the part away, quicker then you can sneeze ! In this case, some sort of manual positioning on your prototype PCB might be the answer ... its not easy to say what type of glue works best (if you really had to go that way), but the temperature sensitive red glue is used because it hardends very quickly over 130 - 150 Celcius, so there's a reason for it being used in some cases ... Having said that, bigger BGA components, say with over 160 BGA balls you hopefully don't need any adhesive at all as the surface tension etc will do the job once the solder is melting ...
citizen
  • 2,241
  • Surface tension is absolutely able to pull a BGA into near-perfect alignment. However, external forces may be able to overpower surface tension and thwart this. Make sure the PCB is perfectly level and the (handheld) hot air is blowing straight down. If the BGA is small, use higher heat and low airflow -- this is almost an IR reflow. If the BGA is large move the tool further away so it heats evenly and use more airflow as necessary. Use silicone walls to protect nearby parts. – Crash Gordon Feb 22 '23 at 17:01
  • @Crash Gordon: I plan using medium air flow, blown straight down, and heat not too high, because soldering SSD NAND chips (18mm x 12mm x 1mm) ; I don't want to increase errors due to excessive temperature. – OuzoPower Feb 23 '23 at 12:26
  • @OuzoPower. The adhesive I was refering to is the Loctite 3609. There are cheaper alternatives out there though. Good luck ! – citizen Feb 23 '23 at 12:59
The main reason for using staking or underfill is to 1) reduce the stress on the BGA solder joints caused by CTE differences between the package and the board, 2) reduce the possibility of the part detaching from the board during a high shock (depth charge near a submarine) or vibration (rocket launch) event and 3) in the case of underfill, provide a better thermal path from the package to the board.
As others have said, you want the part to be able to move a bit during the solder reflow operation, so any staking or underfill is done after soldering and after initial testing shows that the unit works properly.
Whether staking or underfill is needed, and the specific material used, can only be determined after a rigorous structural (for staking) and thermal (for underfill) analysis has been performed.
Staking is preferred to underfill because of the difficulty/impossibility of reworking a BGA that has been underfilled.
Edit 1
Note that on double side SMT boards that go through a solder reflow operation, it is usual practice to use a small bit of adhesive under components to hold them in place, especially those on the underside of the board. However this adhesive is not meant to serve a structural or thermal need.
SteveSh
  • 9,672
What others have said. We use a small under-board preheater (my technician says that is essential) so minimal airflow is needed on top using a hot air pencil. We just bought one of those inexpensive reflow ovens (under USD$500), which with some controller modifications can be quite good for doing small board runs. I saw one in use an an OSHWA meeting a couple years ago and was quite impressed. It has actual profiles and you can add thermocouples etc to do it right but on a small scale. For double sided boards surface tension should hold the upside-down parts on but you can of course use a slightly lower temp solder for the second side. Also you may find a local assembly house that can do small runs for you, and they should even have x-ray inspection for BGAs. There's such a place in Salt Lake City.
bboyes
