I'm trying to read data from combinational logic.
module my_reg(;
  output reg [31:0] rdata;
  always @(data)
  rdata = 32'h18;
and this dut's value is interfaced with a testbench.
module test;
my_interfcae _if();
my_dut u_my_dut (
.HRDATA    (_if.HRDATA),
and the interface is implemented as below:
interface my_interface;
logic [31:0] HRDATA;
endinterface
The problem is that I get the HRDATA at the first 'x in the UVM Driver.
In UVM_DRIVER:
 req.HRDATA = ahb_if.HRDATA;
 $display("R3RDATA: %0h", ahb_if.HRDATA);
Especially, the waveform I captured, you can see the HRDATA has 'h00000012 ,'h00000034 and 'h00000056 so on.
This is the print out from $display("R3RDATA: %0h", ahb_if.HRDATA); in Driver.
How to sample the read data from blocking logic safely in the interface of SystemVerilog without F/F at that point?
toolic
  • 5,637
Carter
  • 581
You have a simulation race condition. You are trying to display a signal value at the same time it is changing. One way to fix it is to add delay before you display. For example, change:
to:
#1 $display("R3RDATA: %0h", ahb_if.HRDATA);
Another way is to change $display to $strobe.
You should always display the simulation time when debugging, something like this:
$display($time, " R3RDATA: %0h", ahb_if.HRDATA);
Since you are using UVM, you should always use `uvm_info instead of $display since it displays the time by default:
#1 `uvm_info ...
toolic
  • 5,637
