I'm building a modular 12 VDC system with individual modules that will step the voltage down to 5 V for powering a microcontroller and a grid of LEDs (4.5 A max per module). These modules can be added or removed from the system at any time. (see the bottom for additional project details)
This is the first time I've developed a hot-swappable system, and I worry about blowing out the modules. Will a good switching step-down voltage converter be enough?
I'm currently looking at the Richtek RT6255A DC-DC converter. The datasheet says:
To control the inrush current during the startup, the device provides a fixed 1.5 ms soft-start up.
Would this be sufficient? Do I need to worry about overvoltage blowing the DC-DC converter? Its maximum voltage is rated at 20 V. How do you approach systems like these?
I've been looking at some hot-swap controllers, like the RT1720, and would love any advice or recommendations you might have.
Additional details
This project is for an interactive LED dance floor installation (project page, original project)
- The system will be powered by a switching 12VDC power supply rated at 100+ watts (connected to mains).
- Each module can draw up to 4.5A each.
- All modules will be within 5 meters of the main power supply.
- In most cases, all the modules will be powered on at once. However, it's possible that some will be swapped in or out at any given time, but this would happen one at a time by hand.
- It takes several seconds to connect or disconnect the modules because of the interlocking base they're built on.
- Between modules, the power will be transmitted through blade-style battery connectors (787614-1 and 5787246-1 on Digikey)
