Edit 3:
I used the following Stackup - in respect to recommendations provided by my board house and the responses to this question.
PCB Stackup
This is a 6-Layer, 0.5mm thick, 1 + 4 + 1 HDI board (Copper thicknesses are not correct in the image).
EDIT 2:
As pointed towards in the comments, i had a look at some youtube videos.
Secrets of PCB Optimization - Rick Hartley - AltiumLive 2020 from 1:18:50 anwards gave me a good hint!
Good video for HDI Design Basics
Edit 1:
As further information seems to be helpful: Here it is!
I am working on a very small board (3x7mm) with double sided load.
Packages used are 0201, BGA (0.35mm, 0.4mm and 0.5mm Grid) and 2x2 12-LGA.
This is a "medium frequency (MCU runs at 150MHz)", low power (15mA), purely digital design.
As previous attempts to route the design on 4 layers failed because of "messy results, bad GND-Layers etc. etc." I decided to give 6-Layers a shot.
Stackup:
From Top to Bottom: Signal-GND-Signal-Signal-GND-Signal.
There are no dedicated power planes, as I can decouple each device and there is only little power draw. I used GND planes as sensitive electronics are used (Strictly recommended by IC manufacturer to use multiple GND-Planes).
Issues I am having:
-As I have double sided load, I use plugged through-vias only very carefully and not to break-out the BGAs.
-As this product will be a small lot size, I need a cost effective PCB design.
My current routing:
Currently I plan on routing like this: Fan-Out BGAs on top/bot layer and via Blind-Vias to associated GND plane (1-2 and 15-16) - Caution: The BGAs are 4x4 Grid - therefore, I only need to fan-out 4 signals to the GND plane.
Signals that need to run from TOP to BOT components are routed by means of through vias. As these signals runs all across the board - yes I tried many component orientations and placements - I need to "unravel" these signals on the inner signal layers.
My question is:
-Which via-arrangement will be - in your experience - the most cost effective?
Yes, I talk to my board-house but I like the input from this forum very much!
Original:
I am interested in information regarding the "correct" way to define a 6-layer board.
My objectives are:
  • Use the "cheapest" stackup available to fit my requirements
  • Be independent of a specific board house
My requirements are:
  • 6-layer with vias from 1-2, 15-16 (1=top, 16=bottom, you get the system)
  • Option to interconnect 2-15 and 3-14 in some way
What I came up with:
  • My first idea is to use the following build-up:
Stackup A
This way, there are three cores (etched, drilled, plated) - then pressed with prepreg and drilled and plated again.
  • My second idea is the following stack-up:
This way, there are two cores etched and pressed, then two prepregs pressed, etched, laser-drilled and drilled normally - then plated.
  • My third idea is the following stack-up:
This way, there are two cores etched, pressed, drilled and plated - then two prepregs pressed and etched, laser drilled and plated.
My question is:
  • What is the most cost-effective and conventional stackup of these three?
ElectronicsStudent
  • 2,746
    You are using the term "stack up" improperly. Stack up means what types signals go on what layer and how the layers are ordered. You are asking about how to arrange the vias. – DKNguyen Feb 14 '23 at 03:36
  • Write down what you relly need. Every kind of micro/blind/buried via adds a bit of cost depending on the board house. Tell them what you want to achieve - some will give good recommendations. Need impedance control? – datenheim Feb 14 '23 at 06:43
  • It kind of depends on your reasons for going beyond 4 layers in the first place. Is it because of physical/space constraints or because of some RF design? – Lundin Feb 14 '23 at 08:57
  • Looking at PCBWay online quoting for one example, in Q 10 adding blind/buried visas multiplies the cost of 6-layer by about 2.5:1. Microvias add cost. Of course if you need it, you need it. – Spehro Pefhany Feb 14 '23 at 10:03
  • @Lundin Because of routing density. I am working on a very, very, very small board. With 4 layers i was not able to get the routing done. – ElectronicsStudent Feb 14 '23 at 10:16
  • @winny A Typo :) Fixed it. Thank you. – ElectronicsStudent Feb 14 '23 at 10:17
    3 by 7 freaking millimetres? So basically, all your routing needs to happen under a BGA? – TooTea Feb 14 '23 at 13:17
    @ElectronicsStudent Please take a moment to look through some of your posts and see how they've been edited. You are a great contributor here but you always have a lot of errors in your questions. – JYelton Feb 14 '23 at 17:36
    Rick Hartley did a whole talk on PCB fabrication and what influences costs, including a lengthy discussion of blind vias and layer connections. It's on YouTube if you search for it. Covers more than your question but likely to be very helpful for your project. – user1850479 Feb 14 '23 at 17:57
  • @JYelton Thank you for the praise. I will put more effort in my future posts. – ElectronicsStudent Feb 14 '23 at 18:29
  • @user1850479 I had a look on Youtube. Thank you very much! This is very helpfull! – ElectronicsStudent Feb 14 '23 at 18:29
None of your proposals is the most conventional and cost effective because they use blind and/or buried vias. Blind and buried vias cost extra. Don't use them unless you actually need them.
enter image description here https://www.proto-electronics.com/blog/how-and-where-use-vias-in-pcb-design
Just because a via hole goes through the entire stackup doesn't mean it connects to every layer. The via hole is drilled then plated, and only the copper layers that connect to the via have copper foil running right up to the plated wall of the via. Layers that are not connected to the via have a clearance hole etched in the copper foil that the via hole passes through so the copper foil never touches the plated walls of the via.
enter image description here https://www.allaboutcircuits.com/technical-articles/which-via-should-i-choose-a-guide-to-vias-in-pcb-design/
But vias arrangement aside, you shouldn't be trying to overspecify your board layer stackup or determining the order used to fabricate the layers. That's micro-managing. You're trying to tell experts how to do their job when you yourself know very little about what their job entails. Tell them what you need, not how to do it.
The cheapest, least board house dependent thing is to let them do what they want within your requirements and not to micro-manage their process. As soon as you dictate and micro-manage their process it's going to cost more. They know the budgetary aspects of their process and what processes are actually available but you don't try tell them how to do their job.
They have a standard setups which alone reduces the cost by virtue of the fact they are accustomed to it and set up for it. Even if that setup does not have the optimal cost incremental unit for your specific board, unless your board quantity is staggering it would overall cost more to change the process. And if your quantity is staggering they would take it upon themselves to change the process to reduce cost.
Design it to what you actually need and don't put unnecessary restrictions on it so the board house has the freedom to do what they do best (and also to allow different board houses to accommodate themselves). If you are doing a regular commercial order with a board house (where a human actually looks at your board files) you can of course ask a rep if there are possible cost optimizations. Little optimizations aren't likely to be very large though unless your board quantities are very high or your board is super custom with a lot of unusual specifications or requirements.
DKNguyen
  • 54,733
  • 67
  • 153
  • Thank you for your response. I actually need the Blind vias 1-2 and 15-16 as BGA Via-In-Pad is used with double sided load. I did google for a bit but could not come up with a answer for my problem. Can you recommend a via/stack-design for my use case? – ElectronicsStudent Feb 14 '23 at 05:40
    You can do via-in-pad without blind vias. Depends on the size of the BGA whether it's practical. The expense of blind vias can be very significant. – Hearth Feb 14 '23 at 06:30
  • Given that OP has all of 21 square millimetres of board real estate to play with, they can probably not afford wasting any of that on through holes (since with those, adding layers is of no help when your traces simply don't want to fit on the board). – TooTea Feb 14 '23 at 13:20
  • @ElectronicsStudent I'm actually not sure of what you are trying to get across in your drawings. Why aren't you just placing vias as required? Why are you worrying about order of manufacture of the layers? You're not the one making the PCB and you don't know their process. – DKNguyen Feb 14 '23 at 14:13
  • @DKNguyen I gave this intention a thought - But i guess, if i can design "willy-nilly" there can be avoideable costs. This is why i am asking. – ElectronicsStudent Feb 14 '23 at 18:28
  • @TooTea Thats my problem :) Do you have any recommendations regarding my question? – ElectronicsStudent Feb 14 '23 at 18:32
  • @ElectronicsStudent The cheapest, least board house dependent thing is to let them do what they want within your requirements and not to micro-manage their process. As soon as you dictate and micro-manage their process it's going to cost more. They know the budgetary aspects of their process and what processes are actually available but you don't so why are you trying to tell them how to do their job? – DKNguyen Feb 14 '23 at 18:48
  • @ElectronicsStudent They have a standard setups which alone reduces the cost by virtue of the fact they are accustomed to it and set up for it. Even if that setup does not have the optimal cost incremental unit for your specific board, unless your board quantity is staggering it would overall cost more to change the process. And if your quantity is staggering they would take it upon themselves to change the process to reduce cost. You're trying to tell experts how to do their job when you yourself know very little about what their job entails. Tell them what you *need*, not how to do it. – DKNguyen Feb 14 '23 at 18:51
  • @DKNguyen You got a good argument here! Was not seeing it from this perspective! Thank you! Your propesed approach - if i read it correctly - is: Just design it with the "best" feaseable technology requirements (so do not go 75um track if you dont need it, e.g.) and pass the design files on and let the magic happen? Would you propose a iterativ process - like: here is my first design, now please tell me what i can do to make it cheaper, then do a redesign according to the input given? – ElectronicsStudent Feb 14 '23 at 18:58
  • @ElectronicsStudent Basically design it to what you actually need and don't put unnecessary restrictions on it so the board house has the freedom to do what they do best (and also to allow different board houses to accommodate themselves). If you are doing a regular commercial order with a board house (where a human actually looks at your board files) you can of course ask a rep if there are possible cost optimizations. They aren't likely to be very large though unless your board quantities are very high or your board is super custom with a lot of unusual specifications or requirements. – DKNguyen Feb 14 '23 at 19:01
  • @ElectronicsStudent That's the advantage of regular board house orders as opposed to batch orders they palletize your order with other peoples' boards to reduce costs, or automated prototype services where no human actually looks at your board. – DKNguyen Feb 14 '23 at 19:06
As others have said, you are describing connections to a via, or the via stack.
In your ECAD software, it is as simple as defining the diameter of your annular ring on that layer. Even if you keep a uniform copper diameter across all layers, your net assignment of the via will define what it connects to electrically.
Now for an example:
In Altium, I have used a 6-layer stackup with BGAs on a small PCB, without needing to utilise microvias. The important thing is the BGA pitch - I had a 0.8mm pad-to-pad pitch, which makes it easier to find via space either between, or in pads.
The vias used were 0.2mm drill and 0.45mm diameter copper.
The crucial point is that this was agreed with the manufacturer before significant design work was done, but they are relatively standard sizes.
The vias are all 'full stack', meaning they are all drilled through the entire thickness of PCB, but I get to choose which copper layers they connect to.
I cannot quantify exactly how cheaper it was, but it was certainly easier for the manufacturer to produce.
The overall stackup was as follows: enter image description here
If I ever start a design with similar constraints, this will likely be my starting point, as I know the manufacturer can produce it, but the best stackup will be design dependent on a case-by-case basis.
raaymaan
  • 1,284
To assess the cost of the various buildups, talk to your PCB manufacturers. They will have their own preferences and standard production methods. However, once you are at 6 layers, expect very similar costs.
Often your requirements will push you down one path.
If you use BGAs, then you will generally want micro-vias to get to all the pads. This needs the core board, then the outer layers must be foil on thin prepregs, laser drilled for blind micro-vias.
If you have dense routing issues, then you can use Manhattan routing (up-down on one side, left-right on the other) on a core layer with buried vias.
There is no one-answer-fits-all. Obvious really otherwise PCB manufacturers would not offer all the different options.
Neil_UK
  • 158,152
  • 173
  • 387
