how are you?.
I'm making an application where a ESP32 is being used as web server, currently I have a web page made to configure the device.
In this pages is a <form>
element, once the submit button is pressed the configuration is sent to the ESP32, I know the data is sent because I'm watching it with wireshark like seen in the following image
and I know the ESP32 is receiving the POST request because of several println sentences that I have in the code, so, the code for processing the request is as follows
server.on("/forma-dato", HTTP_POST, [](AsyncWebServerRequest *request) {
if(!request->authenticate(usuarioHTTP, claveHTTP)) {
return request->requestAuthentication();
request->send(200);
Serial.println("Solicitud de carga de archivos enviada.");
ultimaPaginaCargada = "/config.html";
}, manejaJson);
the callback manejaJSON
is defined as follows and was extracted from this page
void manejaJson(AsyncWebServerRequest *request, String filename, size_t index, uint8_t *data, size_t len, bool final) {
Serial.println("Recibiendo configuración de la dirección IP ." + request->client()->remoteIP().toString() + " " + request->url());
if(!filename) {
Serial.println("No hay archivo.");
if(!index) {
request->_tempFile = SPIFFS.open("/" + filename, "w");
Serial.println("Carga Iniciada" + String(filename));
if(len) {
request->_tempFile.close();
Serial.println("Escribiendo archivo: " + String(filename) + ", tamaño: " + String(len));
if(final) {
Serial.println("Carga completa: " + String(filename) + ", tamaño: " + String(index + filename));
request->redirect("/");
as you can see there are several println sentences to know what the program is doing but none of the messages inside manejaJson callback is being printed so I think the manejaJson callback is not being executed, in addition I don't have any return value from manejaJson and that void definition is made because is the same that defining it as an ArUploadHandlerFunction
as declared int the .on
definition made in WebServer.cpp
of AsyncWebServer library.
bellow is the code to send the data from the web page
if(document.getElementById("forma") != null) { // Si encuentra la forma con la id igual a "forma",
var elementoForma = document.getElementById("forma"); // extrae los valores completos.
elementoForma.addEventListener("submit", function(e) {
e.preventDefault();
var datosForma = {};
var formaDatos = new FormData(elementoForma);
for(var [k,v] of formaDatos) {
datosForma[k] = v;
console.log(datosForma);
var datosJson = JSON.stringify(datosForma)
console.log(datosJson);
var config = new Blob([datosJson], {type: 'application/json'});
fetch("forma-dato", {
method: "POST",
body: config
/*fs.writeFile('config.json', datosJson, 'utf-8', (err) => {
if(err) {
throw err;
console.log("Archivo guardado correctamente");
console.log(config);
/*var envioForma = new XMLHttpRequest();
envioForma.open("POST", "forma-dato", true);
envioForma.send(config);*/
right know the data is being sent by using a fetch method but commented are another two pieces of code to send the data, one with writefile
and the other with XMLHttpRequest, the writefile right now doesn't like too much because of the use of node.js in a completely offline app.
So, what can I do to solve this and being able to process the incomming data.
Thanks in advance for the help.
