Looks like a voltage regulator with marking AC
or A0
, and 9C
on perpendicular to the SOT23 element corpus length.
What it might be?
or A0
, and 9C
What it might be?
This part AO3400, a MOSFET, has the A0 main marking, and a lot marking just where you can see 9C (p6 in the datesheet).
Trace widths make sense, with thick for D & S, and thin for gate with a 1K gate drive resistor.
Also the datasheet specifically calls it out for "load switch" or in "PWM applications", which is what it looks like we have here, especially as the gate drive is coming from the main IC, and the D & S connections match with where the main supply wires come in.
As it would be the main current carrying element in a converter/regulator, it is a natural component to overheat if the output was shorted or excessive load drawn.
Finally it is an "economy grade" component, which fits with other parts we can identify.
