How do I measure voltage between two nodes when neither of them is ground? In the schematic below, I want to measure the voltage between nodes Vmic and Vx. Is it just (Vmic-Vx)? I'm afraid that gives a wrong answer.
Asked
Active
Viewed 551 times
related, possibly a duplicate: https://electronics.stackexchange.com/questions/204096/how-to-plot-voltage-drop-across-a-specific-component-in-ltspice/204097#204097 – PlasmaHH Jan 29 '23 at 20:31
In addition to the other answers, in LTspice you can identify in any command the voltage across two nodes with the syntax
V(node1,node2)
which in your case becomes
V(Vmic,Vx)
Massimo Ortolano
- 815
- 9
- 16
Use a differential voltage probe.
Click on the first node, and drag to the second node.
Neil_UK
- 158,152
- 3
- 173
- 387
You can use .meas Vmicpk MAX(V(Vmic)-V(Vx))*1000
Vmic
and Vx
are node names and not voltages.
The voltages associated with each node are V(Vmic)
and V(Vx)
The difference voltage between the two nodes is V(Vmic)-V(Vx)
Then multiply by 1000 if that's what you want.
- 28
- 351
- 777
