I made a 24 V, 4400 mAh lithium-ion battery using 18650 cells connected in a 7S 2P configuration.
When I check the pack output voltage without the BMS it's around 21 V (very low, undercharged). When I check the BMS output it's around 17 V which becomes 0 V under load.
I think the deep discharge protection has been triggered.
The issue is that the BMS is not letting me charge the battery.
Could I bring back the battery to a decent voltage using my 29 V lithium charger without the BMS, because the BMS is not letting me do so? I'm just scared that doing so might explode the battery or something, so I need some tips.
