I have a remote controlled switch that's connected to a bathroom fan (220v AC, 50Hz). The switch turns the fan on without issues every time. However, when instructed to turn it off, it immediately comes back on. The switch does NOT do this every time and in order to turn it off, I need to send the off command several times. Sometimes, it works the first time, sometimes on the 5th or 6th attempt.
The same switch at the same location, works with a normal light bulb so I'm pretty sure there is nothing wrong with the switch.
I am told that since this happens only with the fan, it could be an inductive kickback which with this particular type of switch, might be turning it back on.
My question is:
- Can a small AC 220v bathroom fan generate inductive kickback (I thought that's DC only).
- Is there a way to prevent this by using something similar to a flyback diode (I understand that on an AC circuit a flyback diode can't work, but I am asking about a similar solution for an AC inductive kickback)
For information, this is the switch: https://sonoff.tech/product/diy-smart-switches/zbmini/
