I am trying to extract the impedance from a sampled signal. Specifically, I have only noisy samples of a sinusoid, of a single period, of current and voltage at a given known frequency. I am trying to implement a method that does not use the FFT, due to potential requirements of the MCU where the algorithm would run.
Back to the question - I can heavily digitally filter those samples and extract a more or less clean sinusoid (this was tested).
My approach starts with the assumption that I can have the phase shift from the cross-correlation that uses a reference phase signal (here: the current), therefore collapses to a dot-product, also normalized for the amplidute variation of the two signals (reference: How do I get the phase angle from Cross Correlation?)
$$\small\theta=\arccos\left(\frac{\sum\limits_{n=0}^{N-1}x[n]y[n]}{\sqrt{\sum\limits_{n=0}^{N-1}(x[n])^2\sum\limits_{n=0}^{N-1}(y[n])^2}}\right)$$
I am not sure about my assumptions here, which are:
  • The real part of the impedance Z is R = VRMS / IRMS.
  • X = 2πf·sin(θ), because when I look around it seems I always need to know C or L, but C or L is actually my unknown.
If this approach is wrong, what about the rectangular notation? I can have:
R = Acos(θ); X = Asin(θ)
It seems that A is the peak value of the sinusoid, but I have 2 different sinusoids with 2 different amplitudes. So what would be "A" in this case?
ocrdu
  • 8,705
  • 30
  • 42
thexeno
  • 1,300
    You should try a DFT on your "simultaneously" taken samples. See this post. https://electronics.stackexchange.com/questions/574979/is-there-a-way-to-measure-the-phase-shift-between-the-input-and-the-output-volta/575011#575011 – Antonio51 Jan 12 '23 at 11:54
    That gets you the power factor, but not necessarily the reactive power because harmonics/noise contribute to the apparent power; you can get phase correlating each (x and y) with sin and cos, i.e., a single-frequency Fourier transform (you can use DFT and take the fundamental bin(s) if you like). – Tim Williams Jan 12 '23 at 11:58
  • The key is that avoiding the DFT would be easier to implemente on an embedded platform (and the cross correlation shoudl habe o(n^2) complexity). – thexeno Jan 12 '23 at 12:48
  • Please, add a picture of your "noisy" waveforms ... and perhaps simplified schematic. – Antonio51 Jan 12 '23 at 12:57
  • I have no schematic, waveform is generated in a C program, that runs the filter. It's still at a theroretical level analysis. The noise is not important, it was to test the filter, but hte sinusoid can be perfect, at this stage. I am not looking for alternatives, but where I am wrong in the math shown before. – thexeno Jan 12 '23 at 12:59
  • Ok ... Not wrong in the math (not checked really). I used the DFT (with only 21 points at 50 Hz with classic Arduino, 8 analog inputs ... not simultaneous, use "corrected delays" of sampling) in my above link to calculate power in one simple 3 phases circuit. It works pretty well. – Antonio51 Jan 12 '23 at 13:10
  • The thing is that I am detecting phase lower than 1 degree. I come from the full FFT approach on python. Too ineffective at the phase part, in my specific application. So I am looking for alternatives, since I do know the frequency of interest and looks more complicated a full FFT just for the impedance. Plus, windowing issues and limited waveforms are further disrupting the result. – thexeno Jan 12 '23 at 13:27
  • If signals are very noizy ... a single period is not enough ... can you give datas you are using. – Antonio51 Jan 12 '23 at 14:12
  • At this point I have basically clean data (perfect sinusoid) to test the basic correctness of the equations I posted. They are just like 2*sin(2*PI*f) and another 2*sin*(2*PI*f + phi). Can be generated with a loop, like "for (int i = 0; i < NUM_SAMPLES; i++) { input_samples[i] = 2*sin(2*PI*i*1/NUM_SAMPLES); ecc" But would generate just a sinusoid of n samples. – thexeno Jan 12 '23 at 14:45
    The calculation shown will generate a close answer, but does not give sign, so you need to add the assumption whether it's inductive or capacitive. In the presence of noise, the difference (intended: apparent minus real equals reactive power) will include Vrms and/or Irms from those other frequencies, not just the actual reactive part. You need a correlation to the voltage at least (and its 90° conjugate), or an independent reference (hence DFT), to measure these. – Tim Williams Jan 12 '23 at 22:30
  • If you attempted such a method before and found poor accuracy, the problems are in the data or algorithm, not the basic method. I wrote such an algorithm for an AVR CPU running at ~100Hz center frequency (and a few hundred samples per cycle) which went fine, easily 16 bits resolution, so, fractional degrees. More accurate anyway than any impedance references I have handy. – Tim Williams Jan 12 '23 at 22:33
  • @TimWilliams thanks. So if I have 80 samples per cycle, I won't be able to get a sub-degree resolution? Or are you referring to the 16 bits result? I might look into it then. But regarding the equations, are you considering correct also the "X = 2πf·sin(θ)" equality I wrote? – thexeno Jan 12 '23 at 23:44
  • I don't know what X or θ is referring to. – Tim Williams Jan 13 '23 at 10:35
  • My mistake, I remove the naming of X from the title. So, X is the reactance of the impedance, θ is the phase shift between the 2 signals of interest. – thexeno Jan 13 '23 at 16:39
  • @TimWilliams I wonder if my correction allows you to understand what was not clear to you... – thexeno Jan 16 '23 at 23:14
  • That's not really what I was concerned with... Like, you have "X = Asin(θ) / It seems that A is the peak value of the sinusoid ...", which is a bit confusing as it seems correct in isolation (X is a function of θ), but not in context (why capital X that we usually use for frequency domain phasors?). If X is a transform, what is it a transform of? x[n] in the equation? It seems not. – Tim Williams Jan 16 '23 at 23:50
  • Anyway, what's wrong with the correlation? If you're generating the wave from the MCU (software DDS?), you already have I and Q available at no cost, or nearly none. Just correlate (read: multiply acquired sample by I, also by Q; accumulate each product into respective registers), then after a cycle, do the trig or whatever on the I and Q parts. It's less effort than the equation shown here (no sqrt or divide required). I suppose I should write this as an answer proper and you can give it a try.. – Tim Williams Jan 16 '23 at 23:53
  • @TimWilliams on your application with "few" hundreds of samples in the AVR, were they more than 360? As the FFT frequency bins are limited by the number of samples, is not also the phase? – thexeno Feb 24 '23 at 07:47
  • It wasn't a binned method (DFT), it's a single frequency correlation; either way, the result is numeric, limited by system noise and computation method. An FFT can be done in floating point for example. What is significant about 360? – Tim Williams Feb 24 '23 at 08:40
  • @TimWilliams An high enougg number of samples. I don't see how mathematically I can appreciate a phase of less than 90 degrees is if I have 4 points per period. So that to have resolution of less than 1 degree, I need hundreds of point, no? I'm looking for some math/links showing this concept, but I'm clueless.... This seems the most related https://www.gaussianwaves.com/2015/11/interpreting-fft-results-obtaining-magnitude-and-phase-information/ – thexeno Feb 24 '23 at 14:12
  • Take four regularly spaced samples along a sine wave. Now shift the phase of those samples. What values would you measure? How would you calculate the phase from the values? (It's just highschool trig.) (Well, I say "just", but if you didn't take that, or didn't do well with it, that would matter quite a bit!) Four samples is the minimum. Well, I suppose you could even use three, but four has better symmetry. More samples are welcome to help exclude noise and harmonics. – Tim Williams Feb 24 '23 at 15:03
  • Define shifting the phase of samples: samples fixed but moving sine? Or moving sampling time? Ps: I don't remember we did discret math in trigonometry at high school, just in uni :') pps: if was so simple, why everyone on the web insists on the fft, or existing projects use megasamples/s and apply the method i shown? Either there a breakthrough here, or a misunderstanding. And the fft is full of problem, see the link before – thexeno Feb 25 '23 at 23:43
Here is a Maple sheet (1 period, DFT application, 3 cases, N samples 1024 & 32 & 8) that "checks the error percentage of the calculated data with some "random" added to the theoretical data.
An with "no noise" for checking ...
Antonio51
  • 11,004
The canonical way to approach this problem is I-Q demodulation.
In RF terms, we're using a synchronous detector/demodulator. A real AC signal has in-phase (I) and out-of-phase (Q) components, or sin and cos if you prefer, and if we simply multiplied a signal (point by point) by a sine wave, we'd lose half that information. So we multiply by cosine as well, and this preserves all information in the signal.
$$ \begin{eqnarray} I & = \int_0^{2\pi} x(t) \sin t \, dt \\ Q & = \int_0^{2\pi} x(t) \cos t \, dt \end{eqnarray} $$
Written here as integral over a single cycle, giving the correlations for that cycle. In practice, this might be done by taking a weighted average of the product over some time window (that is to say, a lowpass filter), as in an analog receiver; or by changing \$d\$s to \$\Delta\$s and integral to summation to give the DSP case (in other words, what you'd implement on an MCU). (A receiver might then take the magnitude (\$\sqrt{I^2 + Q^2}\$) for AM, or the angle change per cycle for FM, for example; but we're doing a much simpler kind of detection here.)
Of course, \$x(t)\$ is one signal; you have two (current and voltage), so you can either assume rather than measure one (when the circuit permits such -- using an op-amp to force voltage, or read current with minimal voltage drop, for example), or repeat the analysis for both. (Your resources seem limited, suggesting the double measurement would be undesirable?)
In case both are measured, you need to divide one by the other to get the normalized phase and magnitude: $$\hat{Z} = R + jX = \frac{I_V + jQ_V}{I_I + jQ_I}$$ (Denoting complex impedance Z with a hat, and voltage and current readings with respective subscripts.)
Measuring just one, you're still doing the same thing (you can't get impedance from units of voltage and current other than by taking their ratio!), but using an assumed value for one of the complex numbers: this will be a calibration parameter, which ideally should be set on initial power-up testing. It may depend on frequency, in which case a lookup table would be helpful (calibrating over a range of frequencies).
And that's it. The \$X\$ can be converted to equivalent L or C, and then we have the R-C or R-L series equivalent circuit at the measured frequency, or we can apply the suitable transformations to get the parallel equivalents.
Which, as long as it's fresh in my mind -- I recently wrote that for a calculator on my website:
Vector Impedance by Resistor Divider | Calculators | Seven Transistor Labs, LLC
Opening dev. console shows the code quoted below (plain old JS):
function vec_Update() {
    var R = parseFloat(document.getElementById("vec_R").value);
    var V1 = parseFloat(document.getElementById("vec_V1").value);
    var V2 = parseFloat(document.getElementById("vec_V2").value);
    var th = parseFloat(document.getElementById("vec_th").value);
    var F = parseFloat(document.getElementById("vec_F").value);
    th = th * Math.PI / 180;
    F = 2 * Math.PI * F;
    var H = V2 / V1;
    var HR = H * Math.cos(th), HI = H * Math.sin(th);
    var ZR = (R * (HR - H * H)) / (1 - 2 * HR + H * H);
    var ZX = (R * HI) / (1 - 2 * HR + H * H);
    document.getElementById("vec_ZR").innerHTML = ZR.toPrecision(9);
    document.getElementById("vec_ZX").innerHTML = ZX.toPrecision(9);
    document.getElementById("vec_ZMag").innerHTML = Math.sqrt(ZX * ZX + ZR * ZR).toPrecision(9);
    document.getElementById("vec_ZArg").innerHTML = (Math.atan2(ZX, ZR) * 180 / Math.PI).toPrecision(5);
    document.getElementById("vec_ESR").innerHTML = ZR.toPrecision(9);
    document.getElementById("vec_ESL").innerHTML = (ZX / F).toPrecision(9);
    document.getElementById("vec_ESC").innerHTML = (-1 / (F * ZX)).toPrecision(9);
    var ZPR = (ZR * ZR + ZX * ZX) / ZR;
    var ZPX = (ZR * ZR + ZX * ZX) / ZX;
    document.getElementById("vec_EPR").innerHTML = ZPR.toPrecision(9);
    document.getElementById("vec_EPL").innerHTML = (ZPX / F).toPrecision(9);
    document.getElementById("vec_EPC").innerHTML = (-1 / (F * ZPX)).toPrecision(9);
This takes in a magnitude and angle as measured by an oscilloscope, but it's immediately decomposed into I and Q parts (HR and HX). A more accurate measurement would be had by taking in the raw waveforms and doing the correlations, but, well, that's rather hard to do from a browser(!).
This also uses a slightly more complicated expression, since the voltage divider has to be accounted for: it's not measuring current and voltage, it's measuring a ratio of voltages. The reference resistance (assumption: its phase is very close to 0°) is a calibration parameter here. In your case, the ZR (\$R\$) and ZX (\$X\$) are given as above.
Incidentally, this method (phase angle by zero-crossing) kind of has the same problem as your proposal; they're quite different in method of course, but in the sense that, they aren't measuring exactly the intended aspect (fundamental sin/cos components), but aspects only related to it (real/apparent power there, zero-crossing here). As such, both are sensitive to components other than the fundamental -- harmonics and noise.
And, if you are in such a situation, where assumptions can be taken, perhaps fairly strong ones -- maybe taking ratios of magnitudes (as yours), or zero-crossing points, or assuming a scalar is wholly real or imaginary as the case may be -- as long as you're comfortable with those assumptions, that can be effective too. Common example: capacitor ESR testers generally measure magnitude voltage, assuming it to be a resistive component; but ESL, and C itself if small, also participate; ESL especially, since the waveforms are often sharp (e.g. square wave). This makes the readings diverge rather dramatically for long lead lengths, or at small values, but such a device is still useful enough as both of those can be controlled. Using one on in-circuit electrolytics of modest or greater value, meets both of those assumptions.
Tim Williams
  • 22,874
  • 71
  • My DFT approach is the application of the (I,Q) calculus (?). As I have shown, for a good search of the phase, one needs a big "number" of periods if "random" noise is added. And sub-degree resolution seems "very" difficult to achieve. – Antonio51 Jan 17 '23 at 08:21
  • To be clear, @Antonio51's method is the generalization of this -- DFT is a faster way (O(N lg N)) to do all frequencies at once. When you know the frequency (e.g. from a DDS source), convolution with it is O(N); and that work can be done incrementally (per sample) so it's easily done on an MCU. – Tim Williams Jan 17 '23 at 13:38
  • That's a clear explanation, thanks. I will measure 2 signals at the same time, I and V simultanously no problem there. My doubt is: would make sense to get I/Q with an internally numerical (assumed) sin/cos, used for the I/Q calc of V, then the same numerical sin/cos for the I/Q cal of I, then making the complex ratio? That is despite I know the I in advance, it must be measured to compensate some circuit parasitics (and this would avoid calibration for this specific case) – thexeno Jan 21 '23 at 11:39
  • Indeed, you can measure the phase and amplitude of the reference and see what it is. It would be maybe surprising to me that an MCU can run fast enough (while getting enough samples/cycle (100s?) to get good harmonic rejection) that significant phase error is produced in the circuit, but that is indeed the way to compensate for it when needed. – Tim Williams Jan 21 '23 at 17:00
  • Firmware (or tricking MCUs to do what I want) is more my speciality, but I might not do everyday certain signal processing stuff, so I am a bit on the learn for it. So I am not sure I understand what you mean by "and see what it is": I would measure I and Q of current, then I and Q of voltage, and calculate Z. The sin()/cos() function of the I/Q gneerted in the FW would be the same sin() I use to propagate the electrical current signal in the circuit. So that would be related. Just checking is these steps are correct in theory – thexeno Jan 22 '23 at 10:50
  • I mean when you print out the I and Qs, the intermediate steps, you may find one of them doesn't change much. Incidentally, this is fine to do in fixed point, but do it carefully of course. Using floats may cost a lot of CPU cycles depending on the platform. – Tim Williams Jan 22 '23 at 19:02
