What ESP32 pins to connect to an NAU8810 audio codec? Or rather the other way around. I need an RX pin. Would this be tied to DACIN?
Pins I'm unsure about:
  • MOUT (Mono Output)
  • ADCOUT (Digital Audio Data Output)
  • DACIN (Digital Audio Data Input)
  • FS (Frame Sync)
  • BCLK (Bit Clock)
What I have so far:
Typical application from the datasheet:
Or does the ESP32 clock not work with this IC?
ocrdu
  • 8,705
  • 30
  • 42
adamaero
  • 606
Both your codec and ESP32 support either PCM or I2S interfaces. You should read about them and decide which one you want to use.
As for which pins to use on ESP32, ESP32 has a fully connected matrix, so you can choose any pin and simply assign a desired function to it in code.
Also check ESP IDF documentation for I2S for more information.
Armandas
  • 7,845
  • 32
  • 56
