I am trying to generate images on a Samsung S22C300H monitor using the Diligent Nexys 7 board running the Xilinx Artix 7 FPGA. Even though the datasheet says the display supports 640x480, I was only able to get it to stop complaining about unsupported signals when stepping up the resolution to 1280x1024. This is the same resolution that the monitor runs at when displaying the OOB program as well. However, I cannot get the display to show anything. The red status light is constant on which means the display is getting valid sync signals. I cannot access the menu while in VGA mode only while my program is running. The menu works when running the OOB program.
I am trying to target VESA 1280x1024 @ 60Hz.
Below is my module, a testbench for it, the constraint file, and the datasheet for my monitor.
I am completely stumped here. The OOB program is written in VHDL which I don't understand and is way more complex than I am able to unravel.
I've read the other suggested threads to this one, and it seems like their issues are all different than mine. If you can get it to work on your monitor please let me know as well.
module GraphicsCard
parameter HSYNC_BITS = 11,
parameter VSYNC_BITS = 11,
parameter HD = 1280, // Display area
parameter HF = 48, // Front porch
parameter HR = 112, // Retrace/Sync
parameter HB = 248, // Back Porch
parameter HMAX = HD + HF + HR + HB - 1, // MAX counter value
parameter VD = 1024,
parameter VF = 1,
parameter VR = 3,
parameter VB = 38,
parameter VMAX = VD + VF + VR + VB - 1
input Clk, Reset,
input [11:0] SW,
output VGA_HS, VGA_VS,
output [11:0] RGB,
output [11:0] LED
// System Clock Buffer
reg clkbuff;
wire clkout;
// Display timing counters
reg [HSYNC_BITS-1:0] hcount = 0;
reg [VSYNC_BITS-1:0] vcount = 0;
// Sync signal registers, vertical counter enable register, and pixel enable register
reg hsync = 0, vsync = 0, venable = 0, pixel_enable = 0;
// Switch state buffer registers
reg [11:0] switches;
// Buffering the Clock
always @ (Clk) begin
clkbuff <= Clk;
end
assign clkout = clkbuff;
// Horizontal counter
always @ (posedge clkout or posedge Reset) begin
if (Reset == 1'b1) begin
hcount <= 0;
venable <= 0;
end
else if (hcount < HMAX) begin
hcount <= hcount + 1;
venable <= 0;
end
else begin
hcount <= 0;
venable <= 1; // Allows the vertical counter to increment
end
end
// Vertical counter
if (Reset == 1'b1) vcount <= 0;
else begin
if (venable == 1'b1) begin
if (vcount < VMAX) vcount <= vcount + 1;
else vcount <= 0;
end
end
end
// Horizontal and Vertical sync signal generator
if (Reset) begin
hsync <= 1'b0;
vsync <= 1'b0;
end
else begin
hsync <= (hcount < HR) ? 1'b1 : 1'b0;
vsync <= (vcount < VR) ? 1'b1 : 1'b0;
end
end
// Assigning register values to outputs
assign VGA_HS = hsync;
assign VGA_VS = vsync;
if (Reset) pixel_enable <= 1'b0;
else
if (hcount >= (HR+HB) && hcount < (HMAX-HF) && vcount >= (VR+VB) && vcount < (VMAX-VF)) pixel_enable <= 1'b1;
else pixel_enable <= 1'b0;
end
// Buffering switch inputs
always @ (SW) switches <= SW;
// Assigning the current switch state to both view which switches are on and output to VGA RGB DAC
assign LED = switches;
assign RGB = (pixel_enable) ? switches : 12'b0;
endmodule
module GraphicsCard_tb ();
reg Clk, Reset;
reg [11:0] SW;
wire VGA_HS, VGA_VS;
wire [11:0] RGB, LED;
GraphicsCard
.HSYNC_BITS(11),
.VSYNC_BITS(11)
) GraphicsCard (
.Clk(Clk), .Reset(Reset), .SW(SW), .VGA_HS(VGA_HS),
.VGA_VS(VGA_VS), .RGB(RGB), .LED(LED)
initial begin
Clk = 1'b0;
forever #4.630 Clk <= ~Clk;
end
initial begin
Reset = 1'b1;
SW = 12'h000;
#9.260
Reset = 1'b0;
#9.260 SW = 12'hFFF;
end
endmodule
## Clock signal
set_property -dict { PACKAGE_PIN E3 IOSTANDARD LVCMOS33 } [get_ports { Clk }]; #IO_L12P_T1_MRCC_35 Sch=clk100mhz
create_clock -add -name sys_clk_pin -period 9.260 -waveform {0 4.630} [get_ports {Clk}];
##Switches
set_property -dict { PACKAGE_PIN J15 IOSTANDARD LVCMOS33 } [get_ports { SW[0] }]; #IO_L24N_T3_RS0_15 Sch=sw[0]
set_property -dict { PACKAGE_PIN L16 IOSTANDARD LVCMOS33 } [get_ports { SW[1] }]; #IO_L3N_T0_DQS_EMCCLK_14 Sch=sw[1]
set_property -dict { PACKAGE_PIN M13 IOSTANDARD LVCMOS33 } [get_ports { SW[2] }]; #IO_L6N_T0_D08_VREF_14 Sch=sw[2]
set_property -dict { PACKAGE_PIN R15 IOSTANDARD LVCMOS33 } [get_ports { SW[3] }]; #IO_L13N_T2_MRCC_14 Sch=sw[3]
set_property -dict { PACKAGE_PIN R17 IOSTANDARD LVCMOS33 } [get_ports { SW[4] }]; #IO_L12N_T1_MRCC_14 Sch=sw[4]
set_property -dict { PACKAGE_PIN T18 IOSTANDARD LVCMOS33 } [get_ports { SW[5] }]; #IO_L7N_T1_D10_14 Sch=sw[5]
set_property -dict { PACKAGE_PIN U18 IOSTANDARD LVCMOS33 } [get_ports { SW[6] }]; #IO_L17N_T2_A13_D29_14 Sch=sw[6]
set_property -dict { PACKAGE_PIN R13 IOSTANDARD LVCMOS33 } [get_ports { SW[7] }]; #IO_L5N_T0_D07_14 Sch=sw[7]
set_property -dict { PACKAGE_PIN T8 IOSTANDARD LVCMOS18 } [get_ports { SW[8] }]; #IO_L24N_T3_34 Sch=sw[8]
set_property -dict { PACKAGE_PIN U8 IOSTANDARD LVCMOS18 } [get_ports { SW[9] }]; #IO_25_34 Sch=sw[9]
set_property -dict { PACKAGE_PIN R16 IOSTANDARD LVCMOS33 } [get_ports { SW[10] }]; #IO_L15P_T2_DQS_RDWR_B_14 Sch=sw[10]
set_property -dict { PACKAGE_PIN T13 IOSTANDARD LVCMOS33 } [get_ports { SW[11] }]; #IO_L23P_T3_A03_D19_14 Sch=sw[11]
## LEDs
set_property -dict { PACKAGE_PIN H17 IOSTANDARD LVCMOS33 } [get_ports { LED[0] }]; #IO_L18P_T2_A24_15 Sch=led[0]
set_property -dict { PACKAGE_PIN K15 IOSTANDARD LVCMOS33 } [get_ports { LED[1] }]; #IO_L24P_T3_RS1_15 Sch=led[1]
set_property -dict { PACKAGE_PIN J13 IOSTANDARD LVCMOS33 } [get_ports { LED[2] }]; #IO_L17N_T2_A25_15 Sch=led[2]
set_property -dict { PACKAGE_PIN N14 IOSTANDARD LVCMOS33 } [get_ports { LED[3] }]; #IO_L8P_T1_D11_14 Sch=led[3]
set_property -dict { PACKAGE_PIN R18 IOSTANDARD LVCMOS33 } [get_ports { LED[4] }]; #IO_L7P_T1_D09_14 Sch=led[4]
set_property -dict { PACKAGE_PIN V17 IOSTANDARD LVCMOS33 } [get_ports { LED[5] }]; #IO_L18N_T2_A11_D27_14 Sch=led[5]
set_property -dict { PACKAGE_PIN U17 IOSTANDARD LVCMOS33 } [get_ports { LED[6] }]; #IO_L17P_T2_A14_D30_14 Sch=led[6]
set_property -dict { PACKAGE_PIN U16 IOSTANDARD LVCMOS33 } [get_ports { LED[7] }]; #IO_L18P_T2_A12_D28_14 Sch=led[7]
set_property -dict { PACKAGE_PIN V16 IOSTANDARD LVCMOS33 } [get_ports { LED[8] }]; #IO_L16N_T2_A15_D31_14 Sch=led[8]
set_property -dict { PACKAGE_PIN T15 IOSTANDARD LVCMOS33 } [get_ports { LED[9] }]; #IO_L14N_T2_SRCC_14 Sch=led[9]
set_property -dict { PACKAGE_PIN U14 IOSTANDARD LVCMOS33 } [get_ports { LED[10] }]; #IO_L22P_T3_A05_D21_14 Sch=led[10]
set_property -dict { PACKAGE_PIN T16 IOSTANDARD LVCMOS33 } [get_ports { LED[11] }]; #IO_L15N_T2_DQS_DOUT_CSO_B_14 Sch=led[11]
##VGA Connector
set_property -dict { PACKAGE_PIN A3 IOSTANDARD LVCMOS33 } [get_ports { RGB[0] }]; #IO_L8N_T1_AD14N_35 Sch=vga_r[0]
set_property -dict { PACKAGE_PIN B4 IOSTANDARD LVCMOS33 } [get_ports { RGB[1] }]; #IO_L7N_T1_AD6N_35 Sch=vga_r[1]
set_property -dict { PACKAGE_PIN C5 IOSTANDARD LVCMOS33 } [get_ports { RGB[2] }]; #IO_L1N_T0_AD4N_35 Sch=vga_r[2]
set_property -dict { PACKAGE_PIN A4 IOSTANDARD LVCMOS33 } [get_ports { RGB[3] }]; #IO_L8P_T1_AD14P_35 Sch=vga_r[3]
set_property -dict { PACKAGE_PIN C6 IOSTANDARD LVCMOS33 } [get_ports { RGB[4] }]; #IO_L1P_T0_AD4P_35 Sch=vga_g[0]
set_property -dict { PACKAGE_PIN A5 IOSTANDARD LVCMOS33 } [get_ports { RGB[5] }]; #IO_L3N_T0_DQS_AD5N_35 Sch=vga_g[1]
set_property -dict { PACKAGE_PIN B6 IOSTANDARD LVCMOS33 } [get_ports { RGB[6] }]; #IO_L2N_T0_AD12N_35 Sch=vga_g[2]
set_property -dict { PACKAGE_PIN A6 IOSTANDARD LVCMOS33 } [get_ports { RGB[7] }]; #IO_L3P_T0_DQS_AD5P_35 Sch=vga_g[3]
set_property -dict { PACKAGE_PIN B7 IOSTANDARD LVCMOS33 } [get_ports { RGB[8] }]; #IO_L2P_T0_AD12P_35 Sch=vga_b[0]
set_property -dict { PACKAGE_PIN C7 IOSTANDARD LVCMOS33 } [get_ports { RGB[9] }]; #IO_L4N_T0_35 Sch=vga_b[1]
set_property -dict { PACKAGE_PIN D7 IOSTANDARD LVCMOS33 } [get_ports { RGB[10] }]; #IO_L6N_T0_VREF_35 Sch=vga_b[2]
set_property -dict { PACKAGE_PIN D8 IOSTANDARD LVCMOS33 } [get_ports { RGB[11] }]; #IO_L4P_T0_35 Sch=vga_b[3]
set_property -dict { PACKAGE_PIN B11 IOSTANDARD LVCMOS33 } [get_ports { VGA_HS }]; #IO_L4P_T0_15 Sch=vga_hs
set_property -dict { PACKAGE_PIN B12 IOSTANDARD LVCMOS33 } [get_ports { VGA_VS }]; #IO_L3N_T0_DQS_AD1N_15 Sch=vga_vs
[Samsung S22C300H Datasheet Link to Samsung.com][1] [1]: https://www.samsung.com/hk_en/support/model/LS22C300HS/XK/#downloads
UPDATE NEW CODE FROM COMMENTS
module GraphicsCard
parameter VF = 1,
parameter VR = 3,
parameter VB = 38,
input Clk, Reset,
input [11:0] SW,
output [11:0] RGB,
output [11:0] LED
reg hsync = 0, vsync = 0, pixel_enable = 0;
always @ (posedge Clk or posedge Reset) begin
hcount <= 0;
end
end
else begin
hcount <= 0;
end
end
// Vertical counter
else begin
if (hcount == HMAX) begin
else vcount <= 0;
end
end
end
if (Reset) begin
hsync <= 1'b0;
vsync <= 1'b0;
end
else begin
end
end
else
if (hcount >= (HR+HB) && hcount < (HR+HB+HD) && vcount >= (VR+VB) && vcount < (VR+VB+VD)) pixel_enable <= 1'b1;
end
endmodule
