I'm looking to use a HX711 chip (which says it's a SOP-16L package,) and attach it to a circuit on a breadboard.
I've found two ways to do so: a socket or just the adapter.
Is there any difference between the two, other than that the adapter requires soldering?
I'm leaning towards the socket, since I barely have any experience soldering.
JRE
  • 67,678
  • 179
kenntnisse
  • 299
The major difference is the soldering as you mentioned.
The socket would allow you to replace the IC quickly - such sockets are used for testing of IC's for instance.
The soldered adapter could give lower contact resistance and maybe a bit less capacitance in total but I think it would not matter much.
I wonder though why you did not buy a HX711 readily assembled on a board with blocking capacitors and so on. For instance sparkfun offers a "SparkFun Load Cell Amplifier - HX711". There are a lot of modules around and you might find one where the pin headers are pre-soldered - so everything ready for breadboard.
Soldering of pin headers to such board might be a good starter to train soldering skills - it's not that magic really :)
datenheim
  • 900
  • Yeah, the project I'm using the HX711 for has prohibited daughterboards like the Sparkfun one, but thanks anyways – kenntnisse Jan 31 '23 at 01:28
