I wrote a synthesizable Verilog HDL code in Xilinx Vivado to implement ECDSA Signature Verification. There are no syntax errors, but synthesis failed. The inputs I am taking are of 7 bits each - r,s,P,Q. I have left out the hashing part(instead I explicitly tried declaring the 32 bit hashed value e, where e = H(m), m being the message of 32 bits.). Still there are errors while synthesis. I have listed out the errors after the code. There are no output bits from this module, so will the Vivado truncate the code? If yes, how should I resolve it?
`timescale 1ns/1ps
module signature_verification(r,s,P,Q);
parameter n = 80;//n is declared to be 80
integer i;
input wire [6:0]r;
input wire [6:0]s;
input wire [6:0]P;
input wire [6:0]Q;
reg e[31:0];
//creating array of elements 1 to n-1
integer verify_array[0:78];
initial
begin
for(i=0 ;i<79;i = i+1)
verify_array[i] = i+1;
end
//check whether r and s integers fall in the array of elements 1 to n-1
initial
begin
for(i=0;i<=80;i = i+1)
begin
if(r[i]!=verify_array[i])//recheck
begin
if(s[i]!=verify_array[i])
$display("Reject the signature.");
end
end
end
//e = H(m) left out
//for the time being skipping the hashing part
e <= 32'b10000000000111000000000001111111
//finding modular inverse of s
function [6:0]w;
input [6:0]s;
input [6:0]p;
integer i;
begin
for(i=1;i<p;i=i+1)
begin
if(((s%80)*(i%80))%80 == 1)
begin
w[i] = i;
end
end
end
endfunction
//computing u1 and u2
reg [6:0]u1;
initial
begin
for(i=0;i<7;i=i+1)
begin
u1[i] <= ((e[i]*w[i])%n);
end
end
reg [6:0]u2;
initial
begin
for(i=0;i<7;i=i+1)
begin
u2[i] <= ((r[i]*w[i])%n);
end
end
reg [6:0]X;
reg [6:0]X_int;
initial
begin
for(i=0;i<7;i=i+1)
begin
X[i] <= ((u1[i]*P[i])+(u2[i]*Q[i]));
end
end
//converting X to v
reg [6:0]v;
initial
begin
for(i=0;i<7;i=i+1)
begin
X_int[i] = int(X[i]);
v[i] <= (X_int[i]%n);
end
end
//checking if v=r
initial
begin
begin
if(r[i]!=X_int[i])//recheck
begin
if(r[i]!=X_int[i])
end
end
end
endmodule
Here I have to check whether X is approaching Infinity. How can I do that in Verilog HDL, since it is a hardware description language unbounded elements cannot be checked?
