15
Charging while using the device reduces battery lifespan*. The charger gets confused in the Constant Current Phase because of the additional current drawn by the device.
Windows OS and some laptop firmwares offer the option to "limit charge to 80%". How does that work to extend battery lifespan?
Not tagging as that's only my main, but far from single, concern.
Had I been asking "how to charge my laptop" I would have gone to https://superuser.com/. Not the case. I seek the physics of it.
* - this interpretation of mine is wrong, for more information see the comments and answers
Vorac
  • 3,091
  • 52
    The link is unrelated. Surely a properly designed device does not have a load on the batteries while charging. And enabling the option to charge batteries to 80% full instead of 100% full gives them longer life as that's how lithium batteries work. In which aspect you ask this to write an answer? – Justme Dec 22 '22 at 09:18
  • If there are some words in the linked question that are relevant to your assertion then please also quote them directly in this question. – Andy aka Dec 22 '22 at 09:22
    "Charging while using the device reduces battery lifespan" - no it doesn't, and that's not what the answers to that question say. – brhans Dec 22 '22 at 13:32
    Your laptop has a sophisticated power control system. The charger is not dumb, and won't get confused because when charging the batteries there will be no unknown loads on the battery. You are mixing different concepts. Having a load on battery while charging is bad, and totally different concept is charge batteries to only 80% full instead of 100% full. It extends the life of batteries as they get less stress. – Justme Dec 22 '22 at 17:56
  • @Justme this, backed by a couple of sources, is the perfect answer. At least to me. (also the expected one but this bears no relevance) – Vorac Dec 22 '22 at 18:56
Charging a LiIon battery to the highest possible voltage gives it maximum capacity, so that is the preferred setting if you intend to use your laptop as a portable computer, because it will run for a longer time.
However, higher voltage will cause the battery to age faster. So, when connected to mains, keeping the battery at 100% charge all the time is not the best. A lower state of charge puts less stress on the battery and will allow it to keep its capacity for a longer time.
The value is a compromise: 50% would be even better for battery preservation, but it is unpractical: in case you actually need to take the laptop away from a socket, runtime will be low and the battery will end up in a deeper discharge, which also ages it faster. So, 80% seems like a good choice.
Basically the end of charge voltage on a LiIon battery is always a compromise between how many years you want the battery to last, and how much runtime you want out of it.
There is another factor: at 4.2V the charger needs to proceed with caution and reduce current because this is close to the overcharge limit. So when the laptop draws pulsed current according to CPU load, the battery may go through many tiny charge-discharge cycles depending on how the motherboard is designed.
If the battery is at a lower state of charge like 80%, the charger does not have to be "careful" to avoid overcharging at all, so it can provide a lot more current without risk, which means, if it is well designed, the charger will provide for all the current the laptop uses, and the battery will not go through these constant microcycles. That's another reason it will stay in good shape for a much longer time.
bobflux
  • 70,433
  • 83
  • 203
  • Fun facts in the later paragraphs! My Universe just got a little wider. Le'me sleep on it; form an opinion. – Vorac Dec 22 '22 at 17:42
    Hehe. If you set the charge voltage to 4.05V instead of 4.2V you can use the LiIon battery pretty much like a capacitor and keep it at this voltage indefinitely. It's great for making a mini-UPS for stuff like Raspi. It still requires a cutoff circuit to avoid overdischarge, but it is simpler than using 4.2V which needs smarter charge protocol. – bobflux Dec 22 '22 at 19:24
    50% is not better for battery preservation with typical use because it means that if you need to remove the laptop from external power and use 30% of the battery, you'll discharge to 20% instead of to 50%. Deep discharges are much worse for lithium batteries than high charge states. – David Schwartz Dec 23 '22 at 06:41
  • "... when the laptop draws pulsed current according to CPU load, the battery will go through many tiny charge-discharge cycles" - Do you have an authoritative source on this? I doubt this is the case. I measured this on my Dell XPS and it's is clearly not doing that. When the 130W charger is connected, the "current pulses" are entirely drawn from the AC charger, the battery sees no current changes even with rapid 0% - 100% CPU load swings. – istepaniuk Dec 27 '22 at 12:24
  • *"If you set the charge voltage to 4.05V [...]"* Just to be sure: a cutoff is also needed to interrupt the charging process at this voltage right, with some hysteresis? I assumed that leaving the LiIon battery at a "floating charge", even a lower one, would not be possible. +1 – MeGrogu Dec 27 '22 at 19:14
    @Grogu no at 4.05V I don't think you need a cutoff. – bobflux Dec 27 '22 at 21:46
    @istepaniuk No authoritative source, so I added a conditional in the answer. I guess it depends on how cheaply it is designed... – bobflux Dec 27 '22 at 21:50
No, it doesn't. The link you provide is from a context very different than a laptop battery. Usage does not interfere with the battery management system.
... the option of "limit charge to 80%". How does that work to extend battery lifespan?
Lithium-ion batteries age primarily with every charge-discharge cycle. There are however secondary factors such as losing 10% to 20% of their rated capacity per year, even if just stored, as metals builds up on the anode.
This and other secondary aging mechanisms are proportional to the cell voltage and hence the lifespan is extended by generally keeping the cells with a lower charge.
Temperature also plays an important role in aging and laptops with "optimized for lifespan" BIOS options might also reduce the charge speed to keep the battery cooler.
istepaniuk
  • 312
  • +1 for the vast useful advice. However those do not seem to answer the question(except for the **voltage** topic, which was not covered in full). – Vorac Dec 22 '22 at 19:07
The things that wear out a lithium ion battery the most are charging it to 100% and running it flat. They are best stored at around 50% charge, and used between about 20% and 80% of full charge.
But laptops spend a lot of their time plugged in and charging. So the battery can sit for hours constantly being topped up to 100%. Capping the charge at 80% gives you less charge when you need to run the device on battery, but means that the battery lasts a few years more.
Simon B
  • 18,609
  • 55
  1. Your understanding of what that question is saying is not complete. A simple 1 IC lithium-ion charger is different than the very complicated power management ICs in a laptop or modern phone. Cut off and topping are handled differently, there are multiple independent paths, advanced monitoring etc. So believing that using while charging will result in a lower lifespan is short sighted.
  2. Using while charging is probably not the main reason a partial charge is used. Even an 85% charge feature will still allow using while charging. And because of 1, this is even an option. Without independent charge control vs the load, you could not stop at 85% without disconnecting the load. And stopping at 85% has the same issues as stopping at 100% then discharging then charging up again. See 3.
  3. The nature of lithium-ion cells is that they have a limited voltage range corresponding with their charge capacity. The higher you charge the more strain you produce on its chemical components. By limiting how much of a charge you put in, it's less stressful, resulting in lower capacity loss issues. Like any battery chemistries which has their own pros and cons and aging issues (remember NiCD and "memory effects") lithium-ion cells have issues with high charges, over discharging, storage etc. You literally have to baby them instead of the normal human usage patterns we have become accused to using (charge and discharge multiple times a day, leave charging for hours after 100%, use in extreme temps both external or internal, etc).
Davide Andrea
  • 16,164
  • 62
Passerby
  • 72,580
  • 90
  • 202
    True "memory effect" was a very rare phenomena, only specific to sintered-plate nickel-cadmium batteries in very particular situations (like those encountered by solar-powered satellites) and is/was otherwise just a myth. – istepaniuk Dec 22 '22 at 17:34
    @istepaniuk - Agree that it only affects Nicads, disagree that it only happens in specific conditions. The standard 'use device for a while then trickle charge for 12-14 hours' will induce it (another reason to avoid Nicads!). – Bruce Abbott Dec 22 '22 at 19:57
  • @istepaniuk True, but [other effects](https://en.wikipedia.org/wiki/Memory_effect#Other_problems_perceived_as_memory_effect) such as voltage depression (which is often confused with memory effect, as it may seem similar) are indeed "pros and cons" of other battery chemistries. – cjs Dec 23 '22 at 10:32
Charging and discharging the battery to extremes will result in dendrite growth. This is what causes batteries to swell and distend, but it also affects utility in that capacity is reduced and by extension effective life.
Keeping between 30% and 70% will go a long way to extending the battery life. 80% also significantly, but I do not have metrics to support this.
Most electric vehicles will recommend 80% or 90% as a limit to extend battery life, but also because of the declining rate of kwh being transferred as the cells approach peak voltage (~4.2V).
As for Chargers, I find that if the battery is heavily discharged, and the load from the device is high, the charger cannot supply the device load and charge the battery. Just a poor match.
In fact, if I have a fully discharged Samsung Galaxy (let's say ~ 3.7V), and I tether my laptop via USB as well as running bluetooth and a WiFi hotspot, I cannot charge the phone from the USB port (500mA presumed). But at 30% it can charge.
mckenzm
  • 175
