I am planning to create a S/PDIF output stream for a digital audio device, but there is some ambiguity on the standard and how it is used. I would like to have the confusion cleared up.
To start, there are two similar standards the AES3 and S/PDIF. The standards are specified by IEC 60958, however I have not found a publicly available documentation. From other sources such as wiipedia, the communication protocol is the same except for one bit, the channel status bit.
The channel status bit specifies among other things the sample rate. In the S/PDIF standard only sample rates up to 48 kHz can be specified from what I understand. In AES3 a much higher rate is available. Yet, there are S/PDIF interfaces with much higher sample rate than 48kHz commercially available.
The question, should I set the channel status bit according to the S/PDIF or the AES3 standard? In addition, if the answer is S/PDIF how to deal with the higher sample rates? Do commercial audio interfaces even care about the channel bits? Are the electronic characteristics at least according to the S/PDIF standard (0.6vpp)?
