I would like to see the signals that I am picking up and I have a DSOX1102G oscilloscope. My probe has a switch that says 10x and 1x.
I have built a 1/4 wave VHF monopole antenna out of a SO239 connector (made to pick up broadcast FM 88 MHz to 108 MHz) with 4 radials, a vertical element, and 50 Ω coax feedline.
When I tell my oscilloscope that I am using the 10x probe and I set the switch on the probe to 10x, my amplitude at frequencies of interest is 140 mV peak to peak. My ground clip is on the coax shield and my probe tip touches the core of the coax cable.
When I tell my oscilloscope that I am using the 1x probe and set my probe to 1x, my amplitude is 10 mV.
My knowledge around this is that the 1x/10x is an attenuation factor; if I set the probe to 10x the scope should do the math and show me the amplitude of my unattenuated signal, right? Why is this reading different from the 1x reading, which to my knowledge is effectively unattenuated?
What is the true amplitude of my signal, millivolts or hundreds of millivolts?
Reading
Antenna
ocrdu
  • 8,705
  • 30
  • 42
Yousif Alniemi
  • 499
    Have you done an analysis to determine what the voltage out of your antenna might be? It could be smaller than you could reasonably expect to see on a 'scope without additional amplification. – SteveSh Dec 13 '22 at 15:18
    In order to do that, you need to know 1) the station's output power; 2) it's directivity; and 3) your distance to the station. You may be able to get that information from the station or from the FCC website (if you're in the US). – SteveSh Dec 13 '22 at 15:20
    Neat idea! I am two miles away from my local NPR station's 25kW transmitter, I figure that I should at least be able to pick that up decently, not sure about its directivity though. Is there some software you have in mind for running an analysis? – Yousif Alniemi Dec 13 '22 at 15:51
  • For wiring to the scope (matched input 50 Ohm), generally use a lambda/4 (calculated at the center frequency) coaxial line ... – Antonio51 Dec 14 '22 at 13:27
My knowledge around this is that the 1x/10x is an attenuation factor; if I set the probe to 10x the scope should do the math and show me the amplitude of my unattenuated signal right? Why is this reading different than the 1X reading, which to my knowledge is effectively unattenuated?
The 1× and 10× settings result in the probe presenting different load impedances to the circuit being probed (antenna). The entire reason scope probe attenuation exists is to load the circuit less (and, especially, with less capacitance) at the cost of lowering the signal.
So, if you use the 10× mode on the probe (and matching 10× setting on the scope, since your scope is not one that has automatic communication with the probe) then you are reading closer to the voltage that is on the end of the coax while it's not connected to anything (open circuit).
However, that does not mean that it's a meaningful reading. In RF circuits, impedance matters. The voltage at the end of the coax while it's open-circuit is not the same as the same as the voltage of the signal when the cable is connected to a receiver.
In order to make an accurate measurement of how this antenna and cable will operate in a proper antenna and receiver system, you need these additional parts:
  • A 50 Ω BNC terminator (50 Ω because that's the same impedance as the cable you are using).
  • A BNC tee connector.
  • An adapter from your coax's connector to BNC.
(You can also use a “feed-through terminator” without the tee; these can give better results, but they are often significantly more expensive. Some oscilloscopes also have built-in switchable 50 Ω termination, but yours does not.)
  1. Connect the tee to the terminator, the antenna cable, and directly to your oscilloscope's input port.
    Do not use the scope probe. Do not use any length of cable between the oscilloscope and tee.
  2. Tell the scope you are using a 1× probe (not 10×), because there is no attenuator in this setup. (Strictly speaking, there is a voltage division going on between the 50 Ω load and the 1 MΩ input impedance of the scope, but that is negligible since the ratio is so large.)
This will get you the voltage reading which most accurately reflects the voltage of the signal that will be going into a proper radio receiver connected to this antenna (which will, similarly, be matched to 50 Ω).
However, there is another caveat to keep in mind: your oscilloscope is a “100 MHz” oscilloscope. Oscilloscopes don't perfectly represent every signal up to their bandwidth limit; the quoted limit is usually (including for yours, according to the data sheet) the frequency that is high enough that signals are attenuated by 3 dB (one-half of the original power). Thus, if you are observing a radio signal at, say, 103.9 MHz, the wave displayed on the scope will be significantly less than the real amplitude.
This is not a big deal for rough order-of-magnitude measurements, but it's important to keep in mind as a limitation of the tool you're using.
Kevin Reid
  • 7,444
  • 44
  • Informative answer. May I ask, wouldn't it be enough for him to connect a 50 ohm resistor between the coaxial output pin and the coaxial shield. Connect the scope probe to the output pin and the probe ground to the shield? (So as to not have to use a BNC?). – ee_student Dec 13 '22 at 05:14
  • (on the assumption that the probe is rated for at least 100 MHz). I'm asking whether the BNC was due to concerns of TL effects at the probe or it has a deeper meaning? – ee_student Dec 13 '22 at 05:20
    Very interesting! I'll look for those parts and try again. If I connect the tee to the scope via the BNC connector that the probe usually connects to, should I tell the scope that I have a 10x probe hooked up? – Yousif Alniemi Dec 13 '22 at 05:25
    @ee_student Yes, that resistor would also work — but it can be tricky to get one in the right configuration without long lengths of wire (that may affect the reading) or soldering together a semi-permanent assembly. Using designed coaxial components just works. The effects would not be _very_ significant at these frequencies, but it's good practice, and these parts are useful for a variety of other experiments too. – Kevin Reid Dec 13 '22 at 05:47
  • Thanks for letting me know. My thought was to order a very simple assembled PCB from easyeda\jlcpcb with a coxial input (signal and ground). Pass the signal through 50 ohm (assembled on PCB). And put a female output pin just above the resistor for the scope probe to go into. (The ground of the circuit will have a track to the coaxial shield connection). – ee_student Dec 13 '22 at 05:51
    @YousifAlniemi Thanks for asking — I forgot to mention that. You should use the 1× setting because there is no attenuator attached — it's a direct connection. See my edited answer for more detail. – Kevin Reid Dec 13 '22 at 05:51
    @ee_student Yes, that would be a home-made “feed-through terminator”. If you were to use such a device, you would use the scope probe in 10× mode, to prevent it from “loading” the circuit and changing the impedance away from 50 Ω. – Kevin Reid Dec 13 '22 at 05:53
  • Last question on my end: is it alright for the scope to receive inputs not passed through high resistances like in the probe? (Assuming we go with BNC). – ee_student Dec 13 '22 at 05:54
  • Ah it has a name (feed through terminator). Wasn't familiar with the terminology. Thanks for assessing my idea. – ee_student Dec 13 '22 at 05:55
    @ee_student Yep! Just like a multimeter in voltage mode, the scope has a very high input impedance so the _power_ delivered to the scope is always low — unless you use that built-in 50 Ω termination option I mentioned! You still have to watch out for the maximum input _voltage_, but that's not a problem here. (But let's wrap this up — comments aren't the place for a big follow-up discussion.) – Kevin Reid Dec 13 '22 at 05:56
  • Got it - scope has high impedance of its own without probes. So power delivered to it (from the original BNC idea) wouldn't cause an issue. Thanks.. – ee_student Dec 13 '22 at 05:58
The 10: 1 probe is more accurate but not impedance matched. An Impedance matched SA or VNA would be best using another antenna as Tx. This would also show standing waves near metal walls. (1/4w null or 1/2w reflection boost.) I once was in an FCC Faraday cage doing susceptibility tests and the operator had a 1kW amplifier hummin at the resonant frequency of the room due the null feedback from the field strength meter.
Probe errors are common if the ground lead inductive reactance is significant relative to the coax capacitance.
Long gnd leads on 10:1 can have a resonance below or the FM band . 1:1 probes are never used > 20 MHz unless calibrated. You may calibrate your 10:1 probe but I suggest you remove probe clip and gnd lead and use a gnd spring adapter or similar around coaxial ring and use pin with a 1cm gap to obtain > 100 MHz BW with a flat response from two close pads or a soldered wire resistor as test pins.
Your sagging wire ground plane can be improved but helps a couple dB. Compare it with a long wire outside the window.
anecdote
In my 1st VHF antenna design, circa '76, I had a protractor jig to measure 3D antenna plots on the roof picking a signal from another building's roof. It was for a BBVI rocket telemetry antenna. It was fun to see it tested in the lab. 1st I rediscovered why VHF antennae makes great intrusion detectors with a return loss bridge with Ricean modulation from reflections. 2nd watch the rocket spin at 10 cps then seeing the SAAB squid release the nose cone and have my braided dipole spread out was a hoot. For some reason, my optimal return loss of 25 dB was slightly shorter than computed. I trimmed this with string to stretch out the cold rolled flat 1/4" braid wire.
  • A 1kHz square wave is inadequate to measure a 100 MHz or more sine wave. Perhaps a 20 MHz square wave. If you have not calibrated otherwise. 30pF will attenuate more using 1:1. Whoever upvoted you was mislead. Do not trust a 1: 1 probe above 20 MHz or suffer great errrors. You can use a matched impedance R pad. – Tony Stewart EE75 Dec 13 '22 at 08:15
  • @Yousif I beg to differ but a scope 1kHz square wave is **NOT** a calibration for a 1:1 probe at 100 MHz . Pls correct your comment or delete it. – Tony Stewart EE75 Dec 13 '22 at 13:06
    That makes sense, I ordered a BNC tee, UHF to BNC adaptor and a 50 ohm terminator..hopefully that can give me a better idea of what is going on. Do you know of an approximate wire gauge that won't sag under its own weight at ~2.5 feet long? I was thinking of buying steel wire for the ground plane to get close to a 45 degree angle – Yousif Alniemi Dec 13 '22 at 14:27
    You can use something that doesn't rust like nylon stranded string or fiberglass supports or aluminum tubing. It will improve the ground plane. but not as good as copper gauze but cheap. – Tony Stewart EE75 Dec 13 '22 at 14:32
    Thanks for the ideas! – Yousif Alniemi Dec 13 '22 at 15:07
