I am new to embedded circuits and working on a problem with which I need help.
I am using ESP32 soc for controlling a bistable valve using DRV8833 driver module. Please refer to this link for valve specifications or a quick reference is available with below table.
The below block diagram refers to the architecture that I am following. Since I am using a bistable valve, if in between the operation there is a power failure or system damage, it continues to be in the state. Even though I can use a monostable valve, I want to make this much less energy-consuming and battery-operated for the long term. I would like to add a fail-safe circuit to the design which should automatically set the state to default state in case the MCU module fails or the power supply goes.
Note: I have tested the valve to be operated using 4700uf/10v capacitor to change the state and it works.
I want to build the red-colored portion as shown in the image.
can anyone light me with a sample circuit for this logic.
