I'm using a NEMA 23 for a solar tracker, which means my mechanism will move a single step every 5~10 minutes, and the step angle is 1.8 degrees which I need to bring down to 0.01 degrees.
Now I need to ensure that there is enough torque to move the mechanism, so I have two options, option 1, either use a large set of gears (compound gear) to reach the desired step angle, which is something I'm trying to avoid since I'm not familiar with designing gears and the compound gear will be difficult to assemble with the body of the tracker.
Option 2, is half-stepping and using a smaller compound gear (less total teeth in total).
Is there much difference between Half-stepping and Full-stepping torque? And. how much of a difference? For me, accuracy and torque are much more important than speed.
toolic
  • 5,637
  • Correct me if I’m wrong but if you’re microstepping then the motor windings are always powered aren’t they? This would eat up a lot of the solar input. – Bryan Dec 06 '22 at 06:19
No, there's not much difference in torque, so you're good there.
However, going down to 0.01 degrees from 1.8 degrees is pretty ambitious, accuracy-wise. Moreover, when you do full steps you can go from the motor's resting position to the next resting position. When you half-step, you have to keep power applied.
If you were to go in 0.01 degree steps, via gearing or whatever, then you could do a full step every 2.4 seconds and power down between steps -- so most of the time the motor wouldn't be powered. On the down side, while in theory your output shaft would advance by 0.01 degree at each step, in practice without a lot of effort you'd experience backlash or mechanical compliance or something that'd make your pointing accuracy much less.
TimWescott
  • 44,867
  • 41
  • Why 2.4 seconds specifically? – Ahmed Sherif Dec 06 '22 at 04:27
  • Work it out (because heaven knows, I may have gotten in wrong). There's 24 hours in a day and 360 degrees in a circle, so... – TimWescott Dec 06 '22 at 04:48
    If he does not like gears, then a belt drive could be implemented for small amounts of money, and the pulleys are available cheaply/3D printable. Is this a solar tracker for a solar panel (in which case you do not need 0.01 degree accuracy, facing the right 10 degrees would probably suffice) or some kind of telescope tracker for looking at the sun? – David Molony Dec 06 '22 at 10:47
  • No it's a solar dish, I've worked it out with my professor, and he agreed that I could have a step angle of 0.05, which is better. Moreover, it will take a step every 10 minutes. thus around 0.5~3 degrees max rotation per step along the day – Ahmed Sherif Dec 06 '22 at 19:38
