I'm designing a H-bridge driven by two IR2110 MOSFET drivers and using four NMOS (IRFS SL7440) transistors. The goal is to transfer power via the two magnetically coupled coils. I am driving the MOSFET drivers at 50 kHz which is the resonant frequency of this magnetically coupled system via the formula: $$ f_{res} = \frac{1}{2*\pi*\sqrt{L*C}} $$
Filling in L=30 uH and C=338 nF gives approximately 50 kHz.
Below is a picture of my schematic, (the first coil is marked by red dots, the second coil is marked by yellow dots)
The problem I encounter is that the current through and voltage over the second coil is too low and too spiked.
Below are two LTspice simulations that show the difference in current and voltage between the output of the H-bridge (=first coil=L1), and the second coil (=L2).
(The current through the first coil is marked in green, while the current through the second coil is marked in deep blue, idem for the voltage plot)
I've tried different resonant frequencies, and changing the coils' characteristics accordingly but the drop in voltage and current remains.
Where could this unwanted drop in power come from?
