enter image description hereI have a SMD it is a SOT23-8 with markings AEIU, I need help identifying or crossing this code to what this might be. It appears to be a comparator.
Rick
  • Thanks everybody!! – Rick Dec 01 '22 at 17:41
  • Rick - Hi, I notice that you commented to say thanks. If your question has been solved, please consider "[áccepting](https://meta.stackexchange.com/q/5234)" the "best" answer for you (i.e. click the "tick mark" next to that answer, to turn it green). This shows that you don't need more help and future readers can quickly see that there was a solution. More about "áccepting" [here](/help/someone-answers). While it isn't *required*, it is strongly *encouraged* to áccept the best answer (in your opinion) which solves your problem. Thanks. – SamGibson Dec 01 '22 at 18:14
It's an MAX9019EKA Dual, Precision, 1.8V Comparator from Maxim Integrated.
From the datasheet, we have markings info confirming the top mark as AEIU:
Marking info
This was found by searching SOT23-8 AEIU. First result in google images was from Aliexpress, showing a chip with the exact same markings (the same font/layout) with the seller listing the part number:
Chip image
Cropped from original image - Source: Aliexpress
Tom Carpenter
  • 63,168
  • 139
  • 196
