I'm building a space heater, not for continuous use, but just as an experiment.
I made a nichrome wire coil that's 3.5 Ω and a fan that blows on it so hot air comes out of the other side of the tube. Everything is enclosed and both electrically and thermally isolated.
For power, the choice was to use a power brick I had salvaged from a junkyard that would output 40 V with 20 A capacity hoping to draw 460 W, but before I could use it, I tested it and it's a dead power brick.
This part is completely hypothetical.
What if I take 240 VAC mains and connect a diode with the heater coil to cut the current?
With the fan blowing on it, and the resistance will also go up as the coils heat, what would be the hypothetical current draw?
My ideal current draw would be 500-800 W. What are my options apart from buying an expensive power brick that's 800 W?
