I am using HC-05 with a Gps module to make a Bluetooth GPS. and i am using 5v mobile charger from the power supply. also using a B0505S-1WR3 Mornsun 5V to 5V DC-DC Converter for further power isolation.
This board is used inside the marine boat and they already have a 24v to 230V AC home ups. The usb adapter is connected to that ups and they working fine, but some time the bluetooth module is resetted to its default value. i cant find the cause and i through it may be caused by voltage surge and i used the SMAJ5.0CA TVS diode at the 5v input to the board, but still i got the same problems.
What may be the problem which resets the HC05 to its default values automatically. Is there any pin which causes the HC05 to its default values?
