I'm planning on building a solar powered pond filter for my koi pond and my setup goes like solar panel to charge controller to inverter module to pump. I have tested the setup and it works when the sun is shining. But there is one problem I couldn't figure out. If the weather is cloudy or overcast then the panel can't produce enough power and the motor might struggle with the undervoltage and fail prematurely. Also a similar situation at dawn when there just isn't enough light to kick start the motor with required stall current, the motor might be struggling and will lead to failure. So is there any circuit or module that can protect the motor from undervoltage and turn it on only when there is sufficient power? I don't want to include a battery with this setup so that's not an option. I'm a beginner when it comes to electronics. enter image description here
Solar panel is a 50W mono PERC type. Charge controller is PWM type with 10A limit, using it to monitor solar voltage and to regulate output voltage to load (inverter). Inverter board and transformer is from an old computer UPS. Wires used are 1mm² multi strand copper. Pump is a submersible type with AC input. I don't know if the motor inside is a BLDC type with it's own circuit board, the internals are epoxied so I can't see what's in it and the manufacturer doesn't provide much info either. The model of the pump is Sunsun JQP-1500.
Kokachi
  • 668
In case you conclude that you really need a cutoff circuit for undervoltage protection - that I believe you don’t need it - there is a sugestion my final paragraph.
The reasons why you may not need the cutoff circuit but you may have other points to consider, then please follow reading.
Some points about your proposed setup:
  • If you are using a SLA battery (missing in the block diagram), your UPS-based inverter probably already has a low-voltage protection circuit, turning the UPS off.
    So, you may not need such cutoff circuit for undervoltage protection.
  • If you intend to not use a LA battery, most probably the UPS circuit will not work, as most computer UPS are rated for 500W or more. The current drain requirements (for ideal 100% conversion efficiency), would need up to 40A at 12V. Assuming 90% Eff. at nominal rating, the standby by consumption may be 4A at 12V, most losses due to (that big) transformer. Adding that pump, another 20W would need ~2A at 12V.
    So, being optimistic, if the UPS inverter is able to start without battery (higher startup current), it would then need > 6A at 12V. But your PV panel is 50W (~4A), so clearly undersized and this setup may not run ok.
  • Talking in terms of Efficiency, using a UPS inverter capable of 500~1000VA to drive a 20W motor source is an overkill and probably will not work properly in steady state: as your charging current may be about 4A but your running demand may be about 6A (said above). So the UPS will drain at 6A a charged battery (for instance 7Ah), the PV does not have capacity to fully recharge it at 4A max (sunny day), the undervoltage protection will trip off the inverter (e.g. 10V), the battery slowly recharges (e.g. 13V), and this short-On & long-Off cycle repeats.
  • About the motor in your (aquarium/pond) pump: such pumps are basically a synchronous permanent-magnet motor, as they have a rotor with a permanent magnet and the field is then driven by the AC line. This motor load is highly inductive, while several UPS inverters were not designed (or intended) to drive such loads.
  • About inverter technology: Depending if the UPS is a real/pure sine wave (PSW) inverter or a modified sine wave (MSW) inverter (some DIY experiments and videos seen here), the synchronous motor may work ok or not - I don’t have personal experience in that, but have seen videos where MSW inverters were used for compressor-based refrigerator (induction motor) and worked, while a microwave oven (HV transformer) did not work ok.
    My guess/bet is that the aquarium pump will run with a MSW inverter - but needs to be tested/checked both dry (quick test) and with water (under load). Surely comments from other fellows would be appreciated.
Possible future investigations:
  • A first point to check is to see if aquarium pumps with synchronous motors work “ok” with the MSW inverter - best guess for the “old UPS” circuit.
    For this test, you may have a similar pump and can power the inverter with any (car) 12V battery.
  • If your UPS transformer is for high-wattage, it’s stand-by consumption will be higher. As you just need 20~50W (run~starting), maybe replacing the transformer by a smaller one (e.g. 12V to 240V 100VA) could make your setup run “continuously”, while you have enough sun.
  • Another possibility is to try a smaller inverter, like those used in the cigarette socket and delivering up to 150~300W. Doing this it could be driven by your 50W PV panel.
Stand alone Undervoltage protection - in case you still need one:
I don’t know if all (small/cheap) inverters have under voltage protection, but if not, you can Google for ready-made “over discharge protection” or “low voltage cutoff” modules, or check for circuits as in this answer with a simple cutoff circuit with simulation results.
EJE
  • 1,412
  • The first point you made is actually something I overlooked. The UPS does have a low voltage protection when the battery gets low. However the 12V 7.2Ah Sealed AGM battery used in the UPS has now been taken out from it and is connected directly to the charge controller. The load output from the charge controller is connected to the battery terminals of the UPS. The scecond point you’ve made is spot on. The UPS has a terrible standby loss (haven’t measured), it loses it’s backup within half an hour even without any load connected. – Kokachi Nov 19 '22 at 19:04
  • Third point, I know it’s overkill but it’s the only decent small sized inverter I could find. Everything else, including the smaller ones have their frequency in the Khz range. And the battery is being charged by the controller instead of the UPS – Kokachi Nov 19 '22 at 19:04
  • Investigation - pump runs ok, so far with my pseudo sinewave inverter. Replacing the transformer is an option. – Kokachi Nov 19 '22 at 19:07
  • @Kokachi , about your 1st reply: I expect the Electronics in the inverter may see an eventual undervoltage in the 12V 7.2Ah SLA and cutoff. The same as using and external/extra battery bank, something that above-average UPS used to allow. – EJE Nov 19 '22 at 20:37
  • About your pump’s reply, although it runs (good to know), it is not clear if mentioned “pseudo” means inverter as MSW (my guess) or PSW. Did you check the videos in the link I posted in the answer? I found quite interesting the waveform improvement using capacitors at high-AC side. Do you have any “portable” oscilloscope to see your actual AC output? If you do, it would be great for us all to see as a “Supplement” this additional info. – EJE Nov 19 '22 at 20:44
  • Pseudo sine-wave is what the UPS manufacturer has labelled. I bet it means a stepped sinewave but unfortunately I don't have scope so I can never verify it's true waveform. If this setup is too inefficient then I guess I better ditch the AC part completely and use a DC pump instead. I'm also planning to upgrade it to a 100W panel according to your suggestion. – Kokachi Nov 20 '22 at 05:01
  • I did a current draw test for the setup. The UPS draws 1.6A from the battery when the pump is running and about 2.5A to start the pump. At idle with no load, the UPS draws 0.6A from the battery, probably the transformer efficiency loss like you just mentioned. – Kokachi Nov 21 '22 at 12:47
  • Since the panel is not powerful enough to both charge the battery and run the pump simultaneously, I decided to change the running mode instead of upgrading the panel. The charge controller will now charge the battery during daytime and the inbuilt dusk-to-dawn feature will run the pump at night when the sun is down. – Kokachi Nov 21 '22 at 12:49
  • I used to have freshwater, fish and coral saltwater aquariums. Temperature management of water has a huge impact on the aquatic life. Considering fish health and beauty of a water fountain (with available/ambient light), I would run it in the 2nd half of afternoon - when water is hottest and a “sprinkler” could either cool down the surface and increase the Oxygen Bio availability - particularly important for Koi and other colder water fishes. Maybe measuring along the day with 2 or 3 temp sensor at different water depths - no pump and pump/fountain, could give you the best start and end times. – EJE Nov 23 '22 at 04:00
