I have a DC to AC power inverter with the following information on the specs sticker:
Input: 12 VDC, 50 A max
AC Output: 115 VAC, 60 Hz, 400 W max (5 min) / 320 W continuous
Given that current in amps is equal to the division of power in watts by voltage in volts, I(A) = P(W) / V(V), is the calculation below correct?
50 A = P(W) / 12 VDC
50 A * 12 VDC = 600 W
And since the information about continuous DC power is given as 320 W, is the calculation for DC to AC power conversion efficiency below correct?
320 W / 600 W = 0.53 efficiency
If the calculations above are wrong, could you please explain and correct me?
ocrdu
  • 8,705
  • 30
  • 42
u20210512
    What is the make/model of the inverter? The efficiency should be in the spec. 50A is the peak power draw, not continuous, so can't be used to calculate the efficiency. – LShaver Nov 15 '22 at 22:21
    The best estimate is to assume that the 50A maximum is drawn when the inverter is providing its naximum which is 400 watts. This results in an efficiency of 400/600 or 66%. – Barry Nov 15 '22 at 22:56
  • @LShaver The inverter is a Duracell DRINV400, and unfortunately I don't see any efficiency information. – u20210512 Nov 16 '22 at 06:45
  • Do you have one? There should be a marking on it somewhere (near things like FCC disclosures, UL listing, etc) that is a Roman numeral (usually V or VI) that tells you the [efficiency class](https://slpower.com/data/collateral/PW174KB_DS.pdf). – LShaver Nov 17 '22 at 18:30
The calculations are not wrong, but you may be misinterpreting the meaning of these specifications
  1. The 12VDC input is the nominal voltage, an input voltage range or tolerance should be specified.
  2. Input current will be highest at full load (400W), not continuous load, and when the input voltage is at the low end of the range. Even under these conditions, it likely won't be as high as 50A.
  3. The 50A max spec is a worst-case value, useful for sizing the power source, including fuses, wiring, switches, etc.
  4. The efficiency will vary with load.
53% efficiency (or even 67%, at 400W output) is a rather low value for full load. If efficiency is not specified, the best way to check is to actually measure input and output voltages and currents at the loads that are of interest.
user28910
  • 3,849
