I'm transmitting analog audio signal from BM20 bluetooth module (it has single ended audio out L + R), to amplifier TPA3118D2.
I wish to add two TRS 1/4 balanced audio output jacks (separate for L and R channels).
I'm controlling AMP mute/unmute via my MCU and also wish to have plug/unplug signal from each audio jacks to handle amp muting.
I'm not good into analog audio, thus I don't know what consequence will below setup have? Will it work properly? I thought about using shield switch but I don't know if it is safe to connect jack shield to system ground.
I could have use jack switches to just control audio path (to amp or to jack), but that will mean that both jack plugs have to be inserted to completly mute TPA3118D2 amplifier.
