I've designed the boost converter below:
Aside from the irrelevant voltmeter parts which are not connected, I'm asking if the way I'm driving the MOSFET is correct.
Working is simple, when TL494 let's current from its transistors, voltage will occur on the TC4420. My concern is that I've put a 20k large resistor which would limit the base current of NPN transistors of TL494 if they even exist. I don't know how exactly TL494 works but in the datasheet it mentions about NPN transistor, collectors and emitters so I assumed it has ordinary NPN transistors inside.
To remedy my concerns, I can move the TC4420 input to collectors and add a 20k resistance between collector and VCC. Since the output is inverted in that case I would replace TC4420 with TC4429 which is inverting version. Two inversions cancel out. I can connect emitter directly to ground and thus let TC494 decide the base current of its transistors.
On the other side, I am open to any suggestions about the converter in general.
Thanks.
