For those who don't know, laser-induced graphene (LIG) is a porous type of graphene that appears after exposing certain types of carbon-based materials with a laser.
In this video, they made LIG on Kapton tape using a cheap 400 nanometer laser engraver module. He used the LIG to make supercapacitors, not to make conductive wires. At the end he used the LIG to make a low-voltage heater.
If I took a Kapton wire, turned it into a LIG wire, used the wire to make a coil and passed an electrial current (a DC current), would it generate an electromagnetic field?
Fulano
    A current flow produces a magnetic field, regardless of medium, including no apparent medium at all (as in vacuum: a propagating wave) – Tim Williams Nov 13 '22 at 15:23
The current through the coil will produce a magnetic field. The voltage across the coil that pushes the current through the coil will produce an electric field.
