I am trying to retrofit 22 high bay LEDs in an armature designed for tungsten halide bulbs (400 W). I understand that I need to cut the capacitor and bypass the ballast.
These fittings are in a hard-to-reach spot (rafters of riding arena), and I am looking for a jumper cable that can be clipped / screwed into place with minimal effort (clamp right through the insulation, no need for cutting / stripping). Hoping to minimize the time I need to spend at the top of a ladder (times 22... it adds up).
I am sure such a cable / connector exists, but I have no idea what it is called, so I can't search for it. I know an "insulation piercing connector" exists for power cables (2/0 AWG); I'm looking for the same thing, but cheaper and in smaller gage (say 12 AWG). I hope somebody here can help identify a suitable solution.
winny
  • 13,064
  • 63
Floris
  • 1,072
  • Not an answer, but are you sure you need to? Some retrofit bulbs are straight retrofit with no modifications needed. – winny Nov 12 '22 at 18:17
    since you're doing electrical work on an arena, thats a public space so you need to be an electrican to do the work, so how is it you don't know this already? – Jasen Слава Україні Nov 12 '22 at 19:44
  • don't use a ladder ... use an elevated work platform – jsotola Nov 12 '22 at 20:10
  • @Jasen it's a private riding arena... not actually a public space. – Floris Nov 15 '22 at 14:10
  • @jsotola - at $350 / day rent, I would like to avoid that since it's coming out of my own pocket. – Floris Nov 15 '22 at 14:10
  • @winny - yes, I checked with the supplier. However if you know of LED bulbs that are compatible with ballast, it would be a win. Might be less efficient... which would offset some of the advantages. – Floris Nov 15 '22 at 14:12
  • Good. They certainly exist to avoid the very problem you are facing. – winny Nov 15 '22 at 18:51
  • @winny - I really appreciate your pointer. I went looking for alternatives, and I found a bulb that is a little more expensive, and a little less efficient - but which is indeed listed as compatible with ballast. Which makes it "screw in and forget about it" easy - worth it for me. So a big thanks! Not the answer to the question I asked - but the answer I needed. XY problem solved. – Floris Nov 15 '22 at 21:22
  • You’re most welcome! – winny Nov 15 '22 at 21:38
given you assertions that this at your home, not at a commercial location.
Search for IDC tap connector be sure to pick one with apropriate agency approvals, and install according to manufacturers instructions.
    Thank you. This is indeed the answer to the question I asked. As I intimated in the comments to the question, @winny pointed out there are some LED lights that are compatible with a ballast; this greatly simplified my problem and is in fact the solution I went with. However, you answered the question I asked, so thank you! – Floris Dec 16 '22 at 22:48
