This question only involves the leaded components.
Electrolytic capacitors are each to recognize since they are usually in cylindrical cans. However, I am not sure about distinguishing the other two types, metal film vs. ceramic, if I come across a device others designed.
HYQ
  • 749
  • What research have you done so far how to distinguish between them? Have you for example googled for images of ceramic and metal film capacitors? – Justme Nov 07 '22 at 21:15
  • They don't look like each other. – DKNguyen Nov 07 '22 at 21:16
  • If you relax the *visually* requirement, film capacitors don't exhibit significant voltage dependence--so if you measure the capacitance with a DC bias of nearly the rated voltage, a film capacitor will have about the same as its rated capacitance, while a ceramic capacitor, if it's a high-κ one (anything bigger than a nF will almost definitely be), it will have probably less than half its rated capacitance. Though if the ceramic cap has a C0G or U2J dielectric, it will look the same as a film cap to this test. – Hearth Nov 08 '22 at 02:27
Not answering per se, but adding an image to illustrate they can sometimes be ambiguous:
Capacitor lineup
Left: marking on top is "22K400∎". 22nF 10% 400V. Appears to be polypropylene (nice high Q factor). Unknown manufacture (salvaged). For reference, it's about 11 x 10 mm, 3.4mm thick.
Center: new (from a couple years ago) TDK FG22X7R1H225KNT06, a 2.2uF 50V 10% X7R ceramic. Basically an MLCC with leads welded on, dipped in epoxy. This is the smallest one here.
Right: 2.4nF 5% 100VDC polypropylene, possibly by TSC Group. Salvaged. Also pretty thin, but a noticeable bulge implying a wound rather than stacked or chip construction.
Most parts you will see in repair will be more obvious.
But this isn't a very design oriented question so I'll leave things at this.
Tim Williams
  • 22,874
  • 71
