NO!
First, the theory:
Dry-charged batteries are not prepared by flooding them, charging and draining them afterwards.
Instead, the plates are press-formed with the approximately proper chemical composition corresponding to a fully or a partially charged battery. In some cases, the plates are formed as a fully depleted battery (they are dry, but not charged and the charging is expected to happen after flooding them).
In either case, there was no even a smell of acid in the batteries when they were shipped.
Absorbing the useful comment from @Pete Becker:
"they weren't transported in a drained condition, they were transported in a never-been-filled condition"
Why it was done:
- Dry batteries were considered safe cargo. One has to still transport the acid, but it is only 10% of the weight (or even less if you carry it concentrated) that has to be transported under the regulatory rules.
- Shelf life wasn't great. Storing batteries dry improved it to a great extent.
Why it is rarely done these days:
- Battery bodies improved a lot. Polypropylene is much better material than bakelite. Caps with valves, etc... Breaking or spilling is much less of a concern.
- Shelf life and self-discharge improved as well, thanks to the technology advance. Today a sealed maintenance-free battery generally has the same shelf life as its dry counterpart from the past.
- The factory can test 100% of the production before shipping. Less RMA, oh, yes!
- Finding someone to deal manually with sulfuric acid is harder these days. Arranging a workplace for them is more expensive as well (see below about the purity).
Dry lead-acid batteries are now only used when compliance with an obsolete regulation is needed.
Some retro-car enthusiasts use them as well. They have their own reasons. Most of them generally try once.
What WILL (not may, but will) go wrong if you go on with your plan:
- About a half of the electrolyte will stay soaked in the plates and the plate separators. The parasitic chemical processes will continue almost as usual. Getting these things dry is not trivial. I bet you can drain the electrolyte and still get some 30% of the electricity out. Some early special-use batteries got such numbers specified for operation in bottom-up state.
In short: you get no storage benefit.
- There is always some sludge at the bottom of the cells of a flooded battery, even in fairly new ones. This is a product of the plates decomposition.
You really, really don't want particles from the positive plates on the negative ones and vice-versa. The plates are not only lead/lead oxides/lead sulphate. They contain additives and the positive and the negative plates contain different additives that are quite counter-productive at the wrong place. They promote self-discharge with hydrogen emission. For an older battery, the sludge can be enough to happily short the plates. In this case, the battery can explode.
You may think of draining the battery from the bottom, using some tube? Your tube has to be less than ~2mm (or less, depending on the battery type) in diameter or it will scrub some active mass from a plate.
Submarine batteries are serviced like this, but they have the tube(s) installed from the factory and they are constructively different in the first place.
- Storing a battery acid outside of a battery is a challenge both in regard to safety and purity.
The battery acid is not immediately dangerous to humans (well, keep it away from your eyes and mouth), but it is corrosive to a great variety of materials and does impressive things to cotton-based clothes.
And then, the purity. Allowing even trace amounts of some substances (e.g. iron) into the battery can kill it rather quickly or at least lower its parameters a lot. Glass container is OK. Glass container washed with tap water is not. You need deionized water for the final rinse. Polypropylene or polyethylene is OK if it is food grade. etc, etc...
In short, top up your batteries with some sane charger and leave them in the basement. Or wherever. Colder is better as long as it is not below, say, -5C.
Most batteries survive a year or two with this storage strategy.
