As above.
I'm confused with the '+xxx" after the percentage. Thanks
This number typically refers to number of "counts", i.e. the least significant digit in each measurement range.
Say you have a 3.5 digit multimeter, and you are measuring a 100.00000 V voltage source.
The multimeter should then (with 3.5 digits) ideally show 100.0 V.
But with a specification of ±0.05%+3 it may show 100*0.005 = 50 mV off due to the percentage error.
In this case, the percentage error would not even show up on the multimeter due to the low resolution. Although when adding the "counts" specification of 3, it may actually show anything between 099.7 and 100.3 V.
Worth to note is that each count is obviously smaller on a higher resolution multimeter (like 6.5 digit). This also means that the counts specification may be higher on a high end multimeter than on a lower end one. But 5 counts on a 6.5 digit multimeter is much better than 3 counts on a 3.5 digit multimeter.
